Question about Samsung HLN467W 46" Rear Projection HDTV
White Flashing I have a Samsung HLN467W after about 45 mins to an hour there is a flashing that starts from intermittent to every other second.  The Flashing is similar to lighting going across any colors.  I have replaced the digital board.  I think due to the time frame that it could be ballast or a cooling issue.  Any ideas???
  • Kevin Wertz
    Kevin Wertz Mar 19, 2012
    Silvera4 did you end up replacing the DMD board? Was this the solution? I have the same model and the same problem and am leaning toward the color wheel even though it is not making any noise.
    President:
  • 4,402 Answers
DMD Control Module is flaking.
Could be getting hot if the fan has been compromised by dust. Take the back off. Clean everything with a brushy on the vac hose. Tape the cover switch shut and power up. Check for proper fan operation. Both should spin equal and quiet. May be too late for DMD Control board, though.
Posted on Feb 06, 2008
Hoover dyn9144dg washing machine door lock flashing wont start.....lock changed still wont start.....light still flashing
Hello the
Plesre and welcome to fixya
can i ask you a question did you unplug the machine and leave it sit for at least 1 hour
See these machines have a internal computer that stores information like any settings that are in the programed in the machine
It normally takes any where from 45 min to at least 1 hour to compete the memory loss on the computer thus resetting the computer ok
so please tell me if you did this if so there is more that we can do ok
Best regards michael
Dec 10, 2013 | Washing Machines
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
Lamp Light on the front is flashing green.
www.pdfee.com/.../Toshiba%20rear%20projection%20training%20manual - United States
www.pdfee.com/search/panasonic+rear+projection+tv - United States
www.scribd.com/.../Hitachi-Training-Manual-Projection-Television-DLP-1 -
Those links should help you understand what's going on. You need to get a service manual, like those supplied, but for your exact make and model.
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=02010300&prd_mdl_cd=&prd_mdl_name=HLN467W
May 07, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Takes 2 hrs to run a 45 min cycle
defo a heating element fault or an ntc fault. More likely to be the element though.
Mar 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Can't set the ttime
Press and hold the hr button for 3 seconds until the 12:00 starts flashing, then press the hr button again to set the hour. Then, press and hold the min button for 3 seconds until flashing starts - press the min button until minutes set.
-Tha Mp3 Doctor
Mar 08, 2009 | GE 106591 Coffee Maker
Samsung HLN467W Flashing "LAMP" LED
remove the lamp and visually check if inside looks broken.if visually do not see any thing wrong,check if you have 300 volts dc supply on the ballast which starts the lamp.if you do then the ballast may be defective.if you do not then the power supply should be checked.
the lamp should always be tried first especially if is older than two years.
note - be aware about the switch at the door lamp.the door should be closed,otherwise tv will not work.if you remove the back cover,make sure to bypass the switch temporarely so you could work on the set.
Sep 03, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Samsung 46 DLP buzzing noise dark picture flashing lamp did not turn off unpluged from wall outlet)
Sounds like you have a bad color wheel assembly which is located in your light engine assembly.
pt#BP96-00250A
Nov 26, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLN467W 46" Rear Projection HDTV Logo
70 people viewed this question
Jerry Greenberg
Jerry Greenberg
