Question about Samsung DVD-V4600 DVD Player/VCR
Dvd wont eject also does three quarters into deck
TAPE WILL NOT EJECT FROM MY Sony J30SDI deck? Manual eject?
unplug from the wall
looks like you can undo the outer casing easily enough
then you can see why it wont eject
Oct 14, 2016 | Sony Audio Players & Recorders
Acer aspire dvd wont open with eject button
Whether you use your DVD drive to install software, make backups of your personal files or watch movies, having that drive onboard makes your computer more useful and more versatile.
While DVD drives function normally most of the time, sometimes a DVD will become stuck in the drive, and the tray will refuse to open.
Knowing what steps to take to resolve the situation allows you to start enjoying the advantages of the DVD drive again.
Log on to your computer and click the "Start" button. Choose "Shut down" from the menu and then choose "Restart." Wait for the computer to restart, then press the eject button repeatedly.
Remove the DVD if the drive pops out.
Since there is no hole skip this and go to cleaning the lens.
Shine a flashlight on the DVD tray and locate the small hole near the eject button.
This is the bypass hole and it allows you to eject a DVD when it becomes stuck.
Insert an unbent paper clip into the hole and push it in until you hear the DVD begin to spin. Push the paper clip in until the drive pops out.
Remove the DVD and insert another one.
Use the bypass hole again if the new DVD becomes stuck.
If the new DVD sticks as well, you need to clean the laser lens on the DVD drive.
Insert a laser lens cleaning DVD and close the tray.
Run the laser lens cleaning program at least three or four times to make sure the lens receives a thorough cleaning.
Restart your computer and insert a DVD to test the unit.
Oct 19, 2012 | Lifetime Acer Aspire 4810TZ-4011...
Hi. How do I fix a CD deck that wont open if I press eject? The deck refused to open with a CD inside. The deck wont play the CD if I press play and wont eject if I press eject. please help. Thanx TC
To retrieve the CD safely, the safest way is to open the unit. A common problem is that a tiny belt from a motor that drives the eject deteriorates and slips so there isn't sufficient drive to move the mechanism. The unit is probably in a mode expecting to eject and has commanded the motor but it doesn't complete... Do as I say and open the unit to do the retrieval. Then get unit serviced.
Dec 04, 2010 | Gemini Sound Products Gemini CDM-3700G /...
I cant open cd
have you tried using a software application to tell it to eject? if this also wont work and all else fails there i a small pin hole in the face of the unit someplace near the center of the deck. if you insert a needle or other stiff small wire into this hole and push gently it will release the cd tray and allow you to retrieve your cd or dvd and in alot of cases return the deck to opening when it should.
Nov 06, 2010 | Samsung TruDirect SpeedPlus DVD-RAM...
Sony TC-WR670 eject wont open deck
I had the same problem. You probably have to replace the rubber belts.
Dec 02, 2009 | Sony STR-DE405
I CHARGE BATTERY BUT IT WONT HOLD CHARGE
Rechargeable lithium batteries have a half-life of about three years. That means half of the capacity is gone is three years - another quarter in another three years. Replacement batteries can be found online. Even if your battery is not that old, this is the most likely reason for short run-life.
It is often possible to get the chemicals in the battery refilled by an online vendor. This is not only cheaper and makes the battery, literally "better than new", but is also easier on the environment.
Oct 06, 2009 | Durabrand PDV-709
The DVD tray doesnt eject
either it is the ribbon wire, the motor that ejects the tray or the belt that connect the tray and motor is the problem. In case the above three are fine, replace the drive as the sparking might kill your moterboard.
Jul 08, 2009 | Compaq (CDD480172) CD-RW Burner
My kenwood ddx6019 wont turn on, but it will eject cd's and has a blinking red light next to the att button
did ya sdo it self cuz if soo you probly forgot to hook up the ignition wire because cds will eject while car is off check for power at ignitiion wire the red one coming from deck harness and then get back to me
Jun 14, 2009 | Kenwood Excelon DDX-7015 Car DVD Player
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
Samsung DVD-V4600 DVD Player/VCR Logo
73 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
