Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
Turn off the power to the appliance. Squirt WD40 liberally all round the knob, trying to get it in behind it. Wiggle the knob and press it down and up if possible to let the WD40 oil work in to the dirty or stuck joints. Leave for a few hours and wiggle it again to see if its loosened up.
Hello, Thank You for using FixYa. I will be helping you today.You have to lift the unit up from the counter use some boards across the counter to support it and remove the screws from around the unit under the glass lip. On some units there are screws under the vent grille also. After removing the screws lift the whole top off.Thats all you have to do.
Thank You and please rate my answer if it was helpful..
The safest thing to do would be to turn off the power ( un-plug it or turn off the breaker) or the gas or both to the unit. Turning off the power would probably be easier. There should be a gas shut off valve behind it.
It sounds like the round burner orifices are dirty. Remove the round orifices and clean in warm soapy water, using a plastic scrubber or toothbrush to remove and dirt and residue around the sides of the burner. Do the same on the little electrode that protrudes at some position around the burner orifice seat.
The system works by the spark ignition module knowing a gas knob is open, and sensing for a flame by ionization within the exhaust gases of the flame. If things are dirty, then the module cannot read the ionization and shuts down the burner, and will also cause the spark to continue.
Also make sure all the burner orifices are properly seated in their holder. If not, the same thing will happen.
