Cars & Trucks Logo
Posted on Jun 13, 2009
Lighter won't work on mini cooper S
My lighter sparked a lot a few weeks ago because a dime fell into the hole. Since then (after taking the dime out) it will not work anymore.
I checked the fuse box and all of the fuses are fine. What now?
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 13, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
3788
Points
17
Check to see what circuit you have missing frst ie the earth to the sigarette light or the power feed
The outside of the holder will be earth and if all the fuses are ok it still will not work if the earth has gone
hope this helps
svs
07923 479640
  • Anonymous Jun 13, 2009
    check to see what circuit you have missing frst ie the earth to the sigarette light or the power feed
    hope this helps
    svs
    07923 479640
2answers
Mini Cooper s 2013 cig lighter not working after a penny fell in it
Check your fuse for the lighter. It most likely shorted out and blew the fuse.
Semper Fi,
Z
tip
Mini Cooper water retension
Can you hear water sloshing around whenever you take a corner in your mini?
A common problem in the new mini is dirt and grime build up clogging the drain holes in the hatchback door (and the boot door on the convertible)
It is quite simple to clean these plugged drain holes. They are rectangle shape about 1/8 by 1/4 inch and there are two of them along the bottom of the door just on the edge of the seam. Clean out using a soft plastic tool. I use a discarded tie-wrap or even a few stiff broom bristles. Don't use wire as it could scratch paint and promote corrosion.
Keep these drain holes clean and prolong the life of your mini.
I feel stupid knowing it took me a week to figure out where that splashing water sound was coming from!
2007 mini cooper turn signal
It could be the relay, a burst bulb or a break in the wiring hope this helps.
Supercharger isnt working , why ??
What does the Service Manager at your local Mini-Cooper dealership recommend for trouble-shooting and repair?
I have an 05 Mini Cooper, Cruise control won't set. Light just flashes 2 or 3 times and then goes off. Was working fine 2 days ago. Any help?
It is flashing a code need to take to a shop and have them put on computer to find out code and replace part.
I have a mini cooper 2007 model and the 12v cigar lighter plug does not work
The lighters element can be burnt out. Look closely and see if there is an open in the spiral metal. If not the case the element plugs into is at fault instead
2helpful
2answers
AC drain for my 2005 mini cooper
Clear out the drain tube. May be able to do it with a coat hanger, or get someone to blow it out with some shop air.
11helpful
2answers
Mini Cooper convertible is overheating, fan contiues after stop
I had this exact same problem -- for about a year and a half! Replaced thermostat, replaced sensor twice, replaced overflow tank, replaced radiator cap, placed a grounding kit on the car in case the problem was electrical ... and was ABOUT to replace thermostat again and then the water pump when a new mechanic suggested we bleed air out of the cooling system. The heater core was PACKED with air, as was the upper hose valve area. Previous mechanic had been using a pressurized fill device to bleed the system and this had just been backing air into the heater core. There are two valves under the hood for bleeding air -- one on the heater core and one on the upper hose. It only takes a few minutes to fix this!
19helpful
3answers
I had the same problem two weeks ago. I have a 2006 Mini Cooper. Brought it into the shop. They changed out the themostat (under warranty). The service advisor said that the 2005 and 2006 Mini's had a problem with the themostat's.
Good luck.
Top Mini Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sam Akber
Sam Akber
Are you a Mini Expert? Answer questions, earn points and help others
