Question about Dell Latitude D600 Notebook
Dell D610 Power lights come and then go off
When I press the power button, lights come on for about 5 seconds and all goes dead...  Any ideas???  It's not the batery.  I have tried a known good batery.
  • 8 more comments
  • Anonymous Nov 09, 2007
    I too have the same problem, when i switch on the power button, the light flashes for 5 seconds and goes dead..
  • paulra Jan 19, 2008
    Ok - milk was split over the keyboard - but after letting it dry the Inspiron 6400 worked again (mouse pad not). A few days later it just turned off and does not start anymore. Power light goes on for a few secs then goes off.
  • houstonles Feb 24, 2008
    i cant get my Dell D610 to come on. i get one green flash when i push the power button. ive unpluged the power cord and removed the battery , and its still dead. what do i do?
  • Anonymous Mar 03, 2008
    d610 shuts off - exactly same issue - i will rush to near by shop - but is there any other quick way ?
  • pkiousis Mar 25, 2008
    I have a Dell D600. I have exactly the same problem. I press the power switch, some power lights come on for about 5 seconds and the go off without ever starting the computer. I try periodically for an hour or so. Eventually the computer starts.
  • Anonymous Mar 26, 2008
    it probably means your motherboard is broken. If no fan or hard drive turning on, and the middle light is flashing, it is a code that the motherboard is broken.
  • Anonymous Mar 30, 2008
    I have the same problem, laptop turns on for 5 seconds then dies. However, if you let it be for more than 10 hrs, it boots, then suddely dies and back to 5 seconds again.
  • Anonymous Apr 02, 2008
    I have a Dell D600 and it;s doing the same and I tried everything and nothing and it was working perfect and from one day to another start doing this, I called Dell Support service and they told me to hold the FN button and press power on but it did not work....any other advice
  • Anonymous May 06, 2008
    same problem the light comes on & cuts right off
  • jakniazi
    jakniazi Jan 07, 2013
    I too have the same problem, when i switch on the power button, thelight flashes for 5 seconds and goes dead..
  • 127 Answers
Check inside the laptop if your processor fan is working properly...sudden shutoff is usually cause when the censor in the board detects that the fan is not triggering to prevent overheating.
going to the nearest PC repair shop would be a good choice.
Posted on Oct 30, 2007
Its probably the disk drive when its corrupted it causes the laptop to shut down remove it then try to turn it back on if it works then it means u need a new disk drive
Posted on Aug 17, 2011
If your computer is running kind of sluggish, you can fix it with an easy clean up of your registry. Here's a link to a free scan that works well:
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
Posted on May 06, 2008
I am having the same issue with a Dell D610. Booted with the FN key pressed in tandem with the power button, a cycle started to run (all the lights blipped in sequence) and then I got a RAM TPM error. I'm in the bios now, will post more soon.
Try checking your ram. If your laptop has no ram the lights will blink and go off. So your ram could be bad.
Posted on Oct 27, 2009
Dell D610 doesn't start at all
I'd go back to the store and make them start it. Anyway there should rather be in guaranty periiod. Ar'nt it?
Dec 01, 2012 | Computers & Internet
Laptop wont even start to power up when power buttonis pressed the green power light comes on for about 4 to 5 seconds then goes off the same thing happens with battery or power packthe same thinh happens...
Problem may be a simle matter of the battery contacts needing to be adjusted so they make better contact for charging and use. Use a needle and ~GENTLY~ raise contact bars on either laptop or battery.
Jul 18, 2011 | Dell Latitude D610 Notebook
My Dell D620 will not turn on. Battery is charged and AC adapter is working. When the power button is pressed nothing happens (the power on light on the laptop does not light up). Does this sound like...
I would start with the miniboard that the power button is attached to. If this is part of the keyboard then that is what you need to try first. Replacement parts should be relatively inexpensive as this is a standard business laptop used everywhere. The D series was very may even be able to use parts from a D610 or a D630. I would start looking for parts on eBay and go from there...
Let me know if you need anything else!
Jun 20, 2011 | Dell Latitude D620 Notebook
My Dell D610 in boot screen appear : '' MANUFACTURING MODE: LEVEL '67''' ''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL ...
Unplug the system and remove the battery. Hold the power button for 30 seconds. Then try powering up -- if it won't, you've damaged the mainboard, and you'll need to replace it.
Dec 22, 2010 | Dell Latitude D610 Notebook
My Dell Laptop D610 wont turn on. It was on, I
Turn off laptop, Remove the battery and the power cable and press the power button for about 30 seconds.
Check for light on AC adapter.
Try with battery alone. Try with AC adapter alone.
Try with a different adapter of the same kind.
else the issue could be with the main board for which I would request you to contact the manufacturer.
Sep 11, 2009 | Dell Latitude D610 Notebook
Dell d610
remove the memory and make sure that the contacts are clean, then be sure to replace the memory correctly & power up as when you power up & the light flashes before boot up this is usually a memory problem i have found with my d600
Jun 15, 2009 | Dell Latitude D600 Notebook
My Dell Inspiron 1000 Laptop would not power up.
possible power supply are motherboard possible bad pin on board
Mar 28, 2009 | Dell Inspiron 1000 Notebook
Powering up a dell d610 laptop
remove the battery and start the machine on AC power only, see if this helps
keep us informed
Nov 24, 2008 | Dell Latitude D610 Notebook
Dell d610 goes off
remove the cd if it is in your drive and remove battery also and see.
Mar 25, 2008 | Computers & Internet
Dell Latitude D600 Notebook Logo
7,189 people viewed this question
Alun Cox
