Question about Sharp AL-1641CS Laser Digital Copier
Doesnt work my sharp digi A161 copier when i turned on the screen showed H and alternates with 4 then d rest of all indication are automatic.. what will i do to make it work normally?
  • Sharp Master
  • 1,113 Answers
H4 - is a heater lamp error - fuser is not heating up - machine needs the fuser repaired before you can use it, it has probally got a blown heat lamp, could be thermister or thermal fuse but usally on these it isn't. If you a teco happy and 240v comfortable then remove fuser and check lamp and components for open circuit, if you do not know what you are dealing with then dont try.... call a tec, this area runs live 240v
now this is under AL-1641CS but you are saying also  Digi A161
so I'll give you both resets use at own risk do not put in any other number but 14, damage will result, but this code I doubt will help you untill original problem is fixed, oyur machine will reset but error again also.
CLEAR - EXPOSURE SELECT- CLEAR - EXPOSURE SELECT really fast like 2 secs, display should blank then 14 start
or Press: "Clear", "Interupt", "0", "Interupt", "14", "Start Key"
Posted on Oct 30, 2007
Tip
Sharp AL Series Copier H3 H-3 code reset procedure
To reset the H3 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This works on the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Mar 20, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier H4 H-4 service code reset
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
on Jan 04, 2010 | Office Equipment & Supplies
While starting the xerox machine SHARP AR 5316 , indicator is showing 4 and blinking everytime, unable to take the printout
I'm going to guess that if you watch the display closely, it is alternating between an "H", and a "4". If that is the case, you have an "H4" error code. This is a fuser error and can either be a freak out from the machine, or an indication of something serious. I would recommend resetting the code and seeing if it comes back. To reset the code, turn the machine on and press "#" -> "Interrupt" -> "Clear" -> "Interrupt". Doing this should put you into service mode, where the display will show a blinking double dash (--). Enter 14 and press the green start button, just like you are trying to make 14 copies of something. At this point, the machine should restart itself and hopefully the error code will go away. If the error code does not go away, or recurs on a fairly frequent basis, I would recommend contacting a professional service technician.
Feb 22, 2011 | Sharp AR-5316 Advanced Digital Imager...
My Sharp 1551CS has a "4" and "H" flashing in the quantity indicator. Copier appears frozen.......HELP!!!
To reset the H4 condition on Sharp AL series copiers press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service. Good Luck and Thank You for using Fixya. WheatlandServices
Nov 29, 2010 | Sharp AL-1551CS Printer
Tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works in the following models:
Pls my Machine Sharp AL-1642cs is showing code: H 4 pls i can't access it so help me out
WheatlandServices
Nov 20, 2010 | Sharp AL-1642CS Copier
Replaced drum cartridge and don't know how to erase the red code on photocopier screen
WheatlandServices
Oct 19, 2010 | Sharp AL-1642CS Copier
I have replaced my drum cartridge on my sharp copier, however, the drum indicator light remains on. How do I get the light to go off?
I am not sure about the 208 but try this procedure I have posted here on Fixya. I beleive it may work for you. It sure won't hurt to try.
To reset the drum light on just about any Sharp AL or AR series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Oct 14, 2010 | Sharp AR-208S Black and White Copier
I have sharp AR-5316E copier, the indicator is
it is the problem your copier fuser unite problem thermostater or heat roller is over temparature . You press # interrupt c inturrupt then 24 press print key 00 then machine is of after on is ok
Jul 13, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL-1641CS Laser Digital Copier Logo
128 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
