Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice dispenser does't work/neither does dispenser light
I have a kenmore elite side by side.  I bought it from someone and there is no model number anywhere on the refrigerator.  I have replaced some parts i.e. the infared sensor which starts and stops the ice maker when ice bin is full, with only part numbers off the old parts.
The problem is that the ice maker makes ice, and the water comes out of the dispenser, but no ice from the dispenser.  The light does not work either.  Bulb is good.  I have checked the voltage to the light and power is 80 volts on both sides when checked to ground.
Some time ago I thought I fixed the problem but just a fluke.  Does anyone have a wiring diagram or know what the voltages are.  I have part numbers which I can give you.  When the light came on then the ice dispenser worked.  The light when off no dispenser motor.  If press the dispenser lock  it shuts off the power to all controls, even if that are incorrect voltages.
  • Anonymous Mar 26, 2008
    My Kenmore Elite 50599003 side by side refrigerator (bought in 2001) has an external ice dispenser. It is not dispensing ice. It appears to me that the lower 'gear' (under the ice receptacle) that is supposed to start/move the 'stirrer' inside the ice holder doesn't move so the ice is trapped inside rather than getting 'stirred' down into the dispenser hole.
  • drscottpt Feb 25, 2009
    I have the same problem, when I push the external "button" to fill a glass with ice the light comes on the chute opens but no ice comes out. Ice is still produced from the maker into the bin. The light still works. I have cleaned the chute, the bin, and can manually turn the auger "stirrer" in the bin without the ice in it. Sears dealer said it was out of warranty and to try blogs.
  • 100 Answers
I can probably get you something send me an email to
Posted on Oct 30, 2007
After changing the water filter, the ice maker is not working. The water dispenser is working properly.
You may need to replace the dual water control valve due to only the water dispenser side of the water control valve being the only side that works. What is the model number of your Kenmore refrigerator? Kenmore model numbers look like this=> 321.235689 as an example. An example of the water control valve if your model number was 321.235689 is part number=> 12001414 Water Inlet Valve
Don't use this example as the correct part. Look around the fresh food section door frame for your correct model number, Thanks
Sea Breeze
Testing the Water Control Valve
Mar 31, 2013 | Kenmore Elite Side By Side Refrigerator -...
I need to replace the ice dispenser motor in a Kenmore Elite model 106.56719500
Go to sears parts direct website, put in model number, locate dispenser and freezer door, should help you, if not get back to me
Sep 12, 2012 | Kenmore Refrigerators
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Ice and water dispenser lock light stays on and comes back on quickly after pushing and holding. No water or ice dispensed while light on. Kenmore Elite 23.1 ft side by side refrigerator
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
May 28, 2008 | Kenmore 25.1 Side-By-Side Refrigerator...
Kenmore side by side
take out ice bin, make sure you get it lined up when put back together, should click,sometimes they are a little off and you have to keep trying, mine has that defect, it works, but only on its terms, its a pain to do, but that can stop it from working due to a safety thing
Oct 30, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No ice through dispenser
When you operate the ice dispenser lever, you should be able to hear a little click from a micro-switch that then switches the auger motor and the light on and also opens the flap. If you cannot hear this small click, then the micro-switch is faulty. The ice dispenser only works when the freezer door is closed, so you could also inspect the door light/fan switch for proper operation.
Oct 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
263 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
