Question about Cobra 148 GTL 120-Channels Base CB Radio
Cobra 2000GTL when i turn the radio off (in a dark room) you can still see the channel display glowing.I have replaced the fet501&502did not fix the problem.any ideas?
  • 1,139 Answers
Re: cobra 2000GTL
Hello wood butcher,
This sounds like a capacitor is not discharging fast enough and has enough residual voltage stored to continue to power the display (to a point). I would check the capacitors that are connected to the vcc of the display matrix and also check to see if one of the resistors has not increased in value due to a possible thermal event.
Tell me how this works out,
Thank you,
Posted on Nov 28, 2007
0 characters
3 Points
88 is displayed in the chanel window
its going to cost you more to fix this problem than the radio is worth.Spend the money on a new radio.
Feb 02, 2014 | Cobra 18 WX ST II 40-Channels Base CB...
Cobra microtallk PR 240-2 radios. One of the radios transmits and receives on a frequency one channel less than the selected/displayed channel. That is, if channel 7 (462.7125 MHz) is displayed, the...
I'm looking at a price range somewhere in the area of 40 - 120 $$ to buy them new. If YOU can fix them without getting a tech involved then go for it but you will need a frequency counter that covers the range and they don't give them away cheap and the repair cost wouldn't be cheap either. I would buy another pair.
Oct 13, 2013 | Cobra CB Radios
Number indicator light only half working, how do i fix?
you need to replace the channel indicator unit. It is an involved process where you must disassemble the radio. lots of small screws then lots of unsoldering and soldering.
Mar 05, 2010 | Cobra 29 LTD CB Radio
Replacement meter swr/rf meter for 25,29 gtl cost
There are a lot of meters on ebay. That's where I get mine.Usually around $5.
As for the other parts, only thing I can recommend is a google search.
Mar 18, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Hard to find Cobra 29 Part #LL-2253YG
there are a whole bunch of channel displays on ebay that will work with your radio.
Jan 08, 2009 | Cobra 29 LTD CB Radio
LED channel selector
you can get them from r& r communications.1-302475-1352 .
Dec 06, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 2000gtl no sound comeing out but will talk on am and ssb can you help
Because you have transmit, more than likely your audio section is OK as much of it is shared with the receive side. A final test of the audio section is to check out the PA function. If it works most of the audio section has been tested.
The signals for the meter movement and receiver sound are developed in the audio detector circuit (diodes D21 and D22) just past the I.F. stages (Transistors TR16, TR17, and TR18). I have seen these diodes fail. They are frail little guys, but are inexpensive. I would recommend replacing them first. Pay particuliar attention to which way the band on the diode is positioned and limit your soldering time. If that does'nt rectify the problem, (no pun intended) you can look at the transitors.
By the way, MOVE that second test radio farther away or you could overload the front end of your Cobra creating even more problems. Good Luck, 302
Nov 26, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
No front panel lighting
The "nightwatch" lighting uses an EL or electroluminescent material that does degrade with age. If the radio is old, then it may be lighting very dimly (check in a dark room with the dimmer at full bright). The material is connected by a ribbon to a special high voltage pulsed powersupply that runs at about 500 volt. If the power supply is working then a new face would be in order or a new radio. If the powersupply is not working it may be repairable but requires working with surface mount components. Either way, it is NOT a simple lightbulb fix. I have successfully repaired and do stock the smc components to repair but cannot get the faces through cobra ($$$). More info? Contact through
Jan 31, 2007 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 148 GTL 120-Channels Base CB Radio Logo
458 people viewed this question
Top Cobra CB Radios Experts
Are you a Cobra CB Radio Expert? Answer questions, earn points and help others
