Question about Toshiba Satellite M35X-S149 Notebook
It boots up normally, then the screen goes black.
I have tried restarting, forced a power down and left the battery out all night last night and the problem recurred tonight. It seems like a setting (maybe one of the function-F keys?) for an external monitor or television hookup perhaps? I want to either restore to default settings or fix it however, but prefer to not wipe the hard drive ... Does anybody know have any suggestions?
Re: It boots up normally, then the screen goes black.
I thing it an operating system problem try to re install it
it dose'nt wipe the hard drive
Posted on Oct 30, 2007
0 characters
3 Points
What would cause my screen to go black and then can't reboot 8.1 on dell pc??
If this is a Laptop, remove battery, Plug in charger to PC and then try to reboot. A bad battery will suck all the power from charger and won't allow the computer to have enough power to boot.
Aug 18, 2014 | PC Laptops
I am unable to get the netbook to boot up. It turns on, I hear the Hard drive humming, but it only goes to a black screen with a cursor that won't work either. All I did is leave it on at night (which I...
Try draining the flea power first
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
check if it will boot to windows, if not, there is a problem with your windows OS, try using startup repair. Hope this helps
Dec 11, 2009 | Acer Aspire One AOA150-1570 Notebook PC
Lenovo 3000 N200 laptop not starting up, power light on
Keep pressed the power button of your laptop for about 30 seconds, the machine will power down.
--The above step may not be required as already so many days passed by.
Then plug it into the power adapter.
Switch the laptop on.
Boot in "safe mode" (F8 during boot).
This will fix any driver or some operating system issue during previous failed boot process.
Once it boots completely, do a normal shutdown and reboot your laptop in standard mode (no more F8 this time).
Now your laptop will be ready to use.
Sep 30, 2009 | Lenovo 3000 N200 Notebook
Restarted computer and it will not start successfully. Error message provides options for restarting in 3 safe modes, last know configuration, or normally. Tried all options and each time, Windows screen...
If you have a recovery cd, use that. Set your bios to boot from cd.
Sounds like the hard drive has crashed and you may have to reformat it and reinstall the OS...or change it.
Aug 14, 2009 | ASUS Eee 4G Notebook
Screen is black. Hear computer trying to boot up.
cpu fan failure try to put a big fan where the comp vents and air flows! and see if its not shutting down!
Jul 01, 2009 | HP Pavilion dv5-1000us Notebook PC
Cannot start up the laptop
Hi there.
That really quick flash of a blue screen is the blue screen of death and there is a possibility that the error could be memory related.
What you have to do is remove and clean the system memory and the slots the memory goes into.
Take out the battery and the AC power (if attached)
The memory will be located behind a panel underneath the laptop, unscrew the panel unclip the memory, clean the brass contacts and the slots with a clean, dry, soft paintbrush, then reseat the memory making sure it clips into place, replace the memory cover and reboot the laptop, see if it lets you into windows.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
May 20, 2009 | Toshiba Satellite A105-S171 Notebook
Black screen with blinking curser in left top corner
Hold the power button down and let it fully power off then boot it back up. If you get a prompt saying Windows did not shut down normally, select Last Known Good Configuration.
May 19, 2009 | Acer Aspire 5315 Notebook
Power Light on but screen black
Try powering up with no battery connected. If that works then the battery may be faulty or too old.
Feb 15, 2009 | PC Laptops
Acer Extensa 5210 laptop wont boot
Try the following:
1) Remove power cord, battery and hold the power switch down for at least 30 seconds.
2) Remove and reinstall your memory module(s).
If those don't do it, get back to me for more ideas.
Dec 14, 2008 | Acer PC Laptops
The laptop doesn't boot up always.
I would try the following:
1. Remove the battery completely. If the computer boots properly several times in a row, then the battery may be causing the power supply to do strange things.
2. If you have experience removing laptop components, try removing the hard drive. Because you say the screen goes black (I assume the system powers off) sometimes after the HP logo, I doubt its Windows or a software issue.
3. If HP has a diagnostic CD you can boot to, try that.
4. It may be the power supply acting up. If it charges the battery, and if you can boot to Windows with the battery, try getting a new power supply.
5. Otherwise, it may be the motherboard of the laptop.
Nov 28, 2008 | PC Laptops
Toshiba Satellite M35X-S149 Notebook Logo
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
