Does the cpompressor come on if not the sound you here maybe the contactor. Check float switch inside. It is underneath the unit or in front of the air handler. Drain stopped up need to blow out drain. Check outside breakers. possible bad capacitor on unit. Need service tech. Rusty
Call a service tech for a free quote. That way you will know what it will cost you. I give free quotes all the time. It is probably a wire burnt of bad breaker or capacitor. The hard part about giving this advice is there is only so much you can tell the person on the other end. Unless they have electrical meters and test intruments. The basic things to check breaker and fuses are ok but when you get into the unit it gets a little more complicated and you might get hurt or damage equipment. You should be able to get repaired for 100 to 150. It sounds like a simple poblem. But remember get FREE quote. Keep calling companies until you get one who does the free quotes. Rusty
So does that mean I have to call a Tech. to service it?
