Linksys Wireless-G WRT54G Router
Problem for Linksys Wireless-G WRT54G Router
I have a virgin broadband modam and a linksys
By lionessahear on Jun 13, 2009
I have a virgin broadband modam and a linksys wrt54g wireless G Router, but i don't have the CD, I connected the router to the modem but could not get internet even though my computer said i am connected. I could or at least use to be able to connect to the routers web page http://192.168.1.1/ manage to make some configurations but I have left 3 security ports open 1.Block Anonymous Internet request
2 filter multicast 3. filter internet Nat Redirection. Is it dangerous to use the internets with these ports open?
I read some blogs relating to how one can get internet with the linksys wrt54g which said to take out the cable from the routers internet port and place it instead into one of the four routers ports this is what i have done. I then could get internet but have been unable to obtain wireless or routers web page, not even when I converted back the cables to their original positions i could no longer obtain routers web page. can u plz advise me thanks . And can you tell me do I have to have the CD inorder to have this router fully functioning? I was under the impression
one does'nt until i encountered these problems.
Solution #1
posted on Jun 23, 2009
Somewhat Helpful)
mike92105
Rank: Apprentice
Rating: 75%, 1 votes
No you do not need internet to access router page. I believe it is 192.168.0.1 though,have you tried this yet?
Comments:
Jun 23, 2009
- you might try "netsh i i r r" in a command window with administrative rights, also reboot the cable modem to make sure it is bound to the correct MAC address.
Was this helpful?
Yes
No
Solution #2
posted on Jul 29, 2009
Not Rated)
mooseamoose
Rank: Guide
Rating: 88%, 2 votes
I think the first step is to get the firmware on the modem.
My suggestion
1) Connect your PC to the cable modem
2) Download the driver to your PC
http://www.linksysbycisco.com/US/en/support/WRT54G
3) Connect your PC to you WRT54G and Cable Modem
4) Select Firmware upgrade
5) Point to the downloaded firmware and install
Turn everything off
1) Turn on cable modem
2) Turn on Router
3) Turn on PC
Hopefully, you will then have an unsecured wireless network that you can then tighten up.
Was this helpful?
Yes
No
Solution #3
posted on Jul 19, 2009
Not Rated)
alexgalapin
Rank: Wiz
Rating: 80%, 38 votes
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
  • in case you cannot access the router's web page on a wried connection:
  • ping IP address: start-run-cmd-ok--on the blinking cursor, type: ipconfig, get the IP address if the IP address is not in the segment of 192.168.1.x.
  • then type: ipconfig/release, and type: ipconfig/renew
  • type ipconfig again, if the IP address is still 198.168.0.x
  • and make sure all the computers connected to the router and the switch is set to automatically detect the IP address and the DNS is all set to auto detect...
  • how to access XP...goto to control panel and select network connections (for vista network and sharing center, manage network connections) and right click on the LAN, select properties select tcp/ip and click properties. and selct automatically assigns IP address and DNS
  • access 198.162.0.1 router's configuration page and set the settings IP addressing to DHCP or auto assigning the IP addresses and the DNS
  • set the router mac address to the middle option set to computer mac address
  • for the wireless, set the ssid to your name, set the region to USA, set the channel to 6 or 11, setr the mode to g and b.
  • then for the external wireless adapter: how to access XP...goto to control panel and select network connections (for vista network and sharing center, manage network connections) and right click on the wireless connections, select properties
  • select tcp/ip and click properties. and selct automatically assigns IP address and DNS.
Was this helpful?
Yes
No
Popular Solutions for Linksys Wireless-G WRT54G
Questions and Unsolved Problems for Linksys Wireless-G WRT54G
Do you recommend Linksys Wireless-G WRT54G Router?
Answer
Answer
i forgot my password how do i find it
Answer
how to do a reset on WRT54G and is there a live chat forum to walk me through setup.
Answer
cant connect to the wireless modem wrt54G even with a wireless g pcmcia card. the modem stops... (More)
Answer
i hook up my router for playstion and only get 50 % conection and also sometimes loose ability to... (More)
Describe your Routers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Router Experts
Top Computer & Laptop Repairmen
in , NV
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
