Question about Acer Aspire 3680 Laptop
Internet connection i cannot connect to the internet
  • 233 Answers
Re: internet connection
Much more information needed!
Try contacting your Internet provider.
Posted on Oct 30, 2007
0 characters
3 Points
How do i restore internet connection please
Restore Internet connectivity ' AVG
To restore lost Internet connectivity please follow these steps: Restart your modem: - Unplug your modem/router from the power supply.
Resetting an Internet Connection (Flush DNS) ' Learning ...
Nov 22, 2015 - To correct it, please flush and reset the DNS by following the instructions below. You may also need to restart your modem and/or router ...
Fix Problems With Your Internet Connection - YouTube
? 6:35
Dec 21, 2015 | Internet PC Laptops
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "" and "Subnet mask" as ""
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"", Subnet mask "", Default gateway-"" and Preferred DNS server: "".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex-, & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | PC Laptops
Ihave a dv6000 laptop and and it has a 1394 net adapter but i can't connect to internet what must i do to connect
The 1394 Net adapter that you see in the Device Manager is simply the Firewire Controller....similar to the USB controller. It is not the same as WIFI or have anything to do with Internet connections...UNLESS you obtain a Firewire network adapter dongle and install it. Then you can connect to the Internet in the same manner as WIFI. The dv6000 DOES have WIFI, as well as a 10.100 Fast Ethernet cable connection that can be used to connect to the Internet.
Mar 18, 2015 | Internet PC Laptops
Why does my "hp envy 15-k073ca" drop internet connections?
There can be several reasons why your Internet connection is slow or keeps dropping. To resolve the issue, you can refer to the guidelines mentioned on the link below:
What are the steps to connect my laptop to my internet services?
Please read the below article for detailed information on hoe to setup the internet connectivity.
It varies depending on the type of connection you wish to choose:
More information and help can be gathered from the ISP you choose for your internet connectivity.
Sep 03, 2010 | Toshiba PC Laptops
How do i share internet with others when I suscribe to internet I was told when I signed up with Tmo that windows settings allow you to share connection.
Windows Settings allow you to share your internet connections providing you have 2 network connections IE: 2 X Ethernet cards 1 X Ethernet Card 1 X Wireless Card. Then on the computer you want to "share" the internet on click on control panel /Network then right click on the card that is connected to the internet you want to share. got to Properties then advance . Tick the box "Allow network users to connect through this computers internet connection" Reboot that PC and any pc connected to that PC either by network cable or wireless will be able to use the internet
Jul 24, 2010 | Dell Inspiron Mini 10 Notebook
Zoostorm 10-270 netbook:how do i connect to the internet? i have a linksys wireless connection which my laptop can connect to but the netbook cant find the signal
your virus software may have blocked your internet connection when connected to your network if you have nortan it intends to block internet connections when theres a threat on your internet connection just uninstall your virus software and install it again.
Apr 01, 2010 | PC Laptops
Wireless internet connection
go into start, connect to, show all connections, click on lan connection, right click on it, repair connection
Oct 17, 2009 | HP G60t Notebook
Cannot connect to the internet
ok... no offense but your statment makes no sense.
So you want to connect wirelessly to a router that is connected to the internet right ?
Feb 23, 2009 | Gateway MX6124 Notebook
Acer Aspire 3680 Laptop Logo
16 people viewed this question
Top Acer PC Laptops Experts
Brian Sullivan
Brian Sullivan
Henk de Ruiter
Henk de Ruiter
Are you an Acer PC Laptop Expert? Answer questions, earn points and help others
