Question about Nikon FM10 35mm SLR Camera
Shutter won't depress, advance lever won't move.
I've had this camera in the box for a long time. Decided to take it out of box again. I just took the film off the spool because I couldn't get the film to advance. Once I did that, the lever did move and I depressed the shutter. Then it seemed to be frozen up again. Somehow it worked, just like that, one more time, now those parts don't move. I don't know what I did (if anything) to 'solve' the problem one time, and don't know what happened that the problem didn't stay solved. I'm new at this, obviously. Maybe the parts are stiff and maybe not.
  • 1 more comment
  • krk2 Oct 31, 2007
    Never mind. I figured it out myself once I got a bit more familiar with the camera.
  • Allison Fay Feb 14, 2009
    yes can you answer our question please. i need serious help because the camera im using is a schools camera and i can't get it to work
  • Anonymous Mar 23, 2009
    I have the same problem with my FM10
How? i have the issue too.
Posted on Sep 08, 2008
How did you fix this i have the same issue
Posted on Jun 24, 2008
3 Suggested Answers
  • 56 Answers
SOURCE: no shutter/film advance
What kind of camera is it,did you check the battery?
Is it a 35mm are what?
Posted on Nov 12, 2007
  • 10319 Answers
SOURCE: nikon fm10 cannot get shuuter release button to
The film lever is also a switch. If you had advanced the film lever, **** it outward a little. You will feel the detent click somewhat when doing so. Leave the lever outward and see if the shutter will work. The detent is for appling an closed circuit for the light meter. When the lever is fully pushed back in it shuts the power to the meter on off to conserve battery power
Posted on Jan 01, 2010
Film not going through camera
E indicates empty.
try resetting the camera. Pus both the rewind buttons (plus/minus button by release button and bracket button on side of mirror box). Push them at the same time. Let the camera run until it stops (just a few seconds). This resets the camera. Then try loading the film again. Make sure the leading edge of the film isn't bent and is the edge is within the red rectangle under the take up spool. It should then load the film. Note: the N75 pulls all the film out of the cassette and then rewinds it back I one shot at a time until you reach '0'.
Aug 12, 2014 | Nikon N75 35mm SLR Camera
Why is my canon ae-1 only developing blank film
First thing I would do is sacrifice a roll of film. Load the film as you have been. Then with the back open and tension on the film (do not touch the film over the shutter, advance the film. It may be that you are putting the film on the takeup spool incorrectly. Watch how the film advances on the spool. If it is on the spool incorrectly it will disconnect then not advance. If that does not work it may be a errant takeup spool.
Jul 06, 2012 | Canon EOS-AE-1 35mm SLR Camera
I've taken many photos so far with my Canon T70 but have no idea how many and when to stop.. i'm not counting the number of photos i've taken, haven't heard any beeping and don't know...
The maximum number of shots possible is 24 or 36 depending on the film length, although sometimes you can squeeze an extra one out of a film. If the film loaded correctly you will get a frame counter in the LCD. If the film did not load correctly, then you have not taken any photos as the film is still in the canister and unexposed.
Take the camera to a totally dark room (and I do mean absolutely pitch black) and open the camera. if you can feel the film canister and just the short leader then it didn't load and you can turn on the lights and try loading again. if there is just the canister and no film sticking out, then the film has rewound and you can turn the lights on and send the film for developing to see if the camera worked. If you feel film going from the canister right across to the take-up spool, then your film is still being used and you should close the back of the camera before turning on the lights again. The latter does not necessarily mean that your camera is OK though as it should be showing frame numbers, but it may be usable still. If after a few more shots the camera is still behaving just the same then it's got a fault.
A faulty t70 is really not worth repairing. It's complex, spares are mostly unavailable, and they are almost worthless even in perfect condition. Any of the earlier non-t-series Canon FD-mount bodies are far better and a lot more fixable. They are also usually near worthless and can be picked up free or very cheaply, but as they have less to go wrong and were designed with repairs in mind then many common faults can be fixed.
Jul 27, 2011 | Canon T70 35mm SLR Camera
What does the E mean on the screen.I put a new film in at Xmas time and only took a few pictures when the E showed up and couldn't click the picture. took to camera shop replaced batteries and film ...
If you go to you can find the manual for your camera. From my experience the E on a Pentax camera means the film isn't loaded properly. Hope this helps.
May 11, 2011 | Pentax Photography
Loud grinding noise when I "****" the film.
does this noise happen with film loaded or all the time?
this could be a broken gear or the take-up spool is slipping. with the film door opened advance the lever and check if the take up spool is turning. if not turning then a gear is broken. if the spool is turning then the spool is slipping.
there are no new parts available for the K1000, however some camera repair shops have good used parts that can be used.
the take-up spool was one of the very few weak parts of the K1000, you can make a temp. repair if you want.
on the take-up spool push down lightly on the gear like wheel and rotate the spool you should see a hairline crack under where the film is inserted. check both sides. if you find the crack put a very small amount of super glue on the crack using a tooth pick or similar tool. this works 80% of the time.
if you take or send your K1000 to a camera repair shop get an estimate first.
Feb 23, 2009 | Pentax K1000 35mm SLR Camera
When i re-load film the shot counter reads " error"
Film didn't catch spool.
Try to put film on the spool, catch tooth on the spool.
Feb 05, 2009 | Nikon F80 35mm SLR Camera
Film Advance Problem
The take up spool is cracked at the base causing the spool to slip. The camera must be mostly disassembled to replace the spool ( if available ) . This is one of the very few weak parts in the K1000. send or take it to a camera repair shop for an estimate first. --- or--
separate the base of the spool by pushing down on the gear like wheel and if you find the small crack from the bottom of the spool film slots, very carefully put a dab of super glue on the crack. check both sides of the spool. this works about 80% of the time. however it's better to replace the spool.
Jan 21, 2009 | Pentax K1000 35mm SLR Camera
Pictures didn't develope
Looks like you are not loading the film onto the take-up spool correctly.
Go back to the development store and ask them if they can give you a spool of waste film (e.g. one that got exposed to the light or something). Otherwise buy the cheapest film you can find.
Load the film in the camera. Take a few frames. Open the camera back up a bit, the film should have advanced. You will be able to tell this because there is more film on the takeup spool. The frames are also numbered nearby.
It might take you a few goes to get the film to load correctly. If no luck, maybe the file wind-on is broken and the camera needs repair.
Nov 05, 2007 | Nikon N65 35mm SLR Camera
Nikon n75 problem loading film
I have (had) the same problem. I came onto this site to find out what I can do to fix it. It didn't help. I got pissed and almost threw the camera away. So I decided to get a little rough with the camera, (i normally wouldn't do this but i was going to throw it away).
I loaded the film like normal but before I closed the back I manually wound the film around the opposite spool. I guess I fooled the camera into thinking it had already wound the film.
When I closed the back of the camera everything worked fine.
I then snapped off the pics the camera said were left.
After this first role, I loaded the next role like normal. The camera worked like a charm!
By the way...the mirror dropped back down when I manually wound the film around the spool.
I hope this works...if it doesn't make any sense feel free to email me with any questions..
amasseur at gmail dot com
Oct 03, 2007 | Nikon N75 35mm SLR Camera
Canon A1- Just stopped working
Get a dummy film and put it in the camera , make shure that the film is fully loaded on to the take up spool and test it all the way through, It sounds like the film is coming off the take up spool. I have repaired a lot of these A1's and they don't suffer from this problem. yours Tim 01689 818009..
Oct 03, 2007 | Canon EOS-AE-1 35mm SLR Camera
Nikon FM10 35mm SLR Camera Logo
373 people viewed this question
Top Nikon Photography Experts
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
