Question about RCA D44LPW134 44" HDTV
Loud noise from tv
D44LPW134yx1 The tv makes a loud noise when you try to turn it on the noise comes from the lamp area dont know if its the lamp or the fan. If you leave the tv off for a couple day it will work fine for a while then do the same thing agin the bulb looks fine. Any help would be great thanks
  • jayh2o Oct 31, 2007
    Thnaks for the help.
    Where can i buy or order the right wheel for the tv?
    Thanks for your time
  • lakerock Dec 03, 2007
    Same TV, 2 years old. Noise is around 60hz, and is not the lamp fan. Putting pressure on the lamp box by hand will change the sound but not eliminate it. Before looking at the problem, I thought it might be a tranformer hum, as it is similar in sound. Now I'm thinking its a rotating part in the projection system, and there is also a low frequency (0 - 1 Hz) modulation component to the sound. Picture is fine, very good actually! Any suggestions on what to do?
    Problem Solver:
  • 8 Answers
If this is a very annoying screeching or sqeualing type sound, it is, in my experience, the "color wheel" which is located inside the lite engine. this is a replaceable component whick costs about $110....i've done this repair many times with no problem....
Posted on Oct 30, 2007
  • Frederick Bates Oct 31, 2007
    you can order that online. go to Tritronics website from there you can enter model # and a list of components will come up and you can select it from there....let me know!
Bulb has gone out and now makes a loud noise
The noise depending on where it came from may be normal. You wont be sure unless a TV repairman checks the boards to know for sure, or you could replace the bulb and hope for the best.
Jul 19, 2010 | Panasonic PT-56DLX75 56" HDTV
Tv making a loud noise and the lamp status light
Replaced the lamp.Might also be light engine blast too.
Dec 17, 2009 | Televison & Video
Loud noise coming from Lamp area
The fans in these generaly do not go bad, the part nubmer for the lamp cooling fan is 265943. But my guess is that the color wheel is starting to go out of you light engine. I am not sure if these are still avalable but the part nubmer for it would be 267888. Worst case you could send your engine in for repair engine nubmer should be 265864 or order a repacement try this site. GOOD LUCK
Aug 13, 2009 | RCA HD50LPW165 50" Rear Projection HDTV
Tv makes loud noise in the area of lamp
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...thank u!!!
rate me
May 29, 2009 | Samsung Televison & Video
T.v. clicking and wont turn on..
The loud pop you heard is usually indicative of a failed lamp. The clicking noise you hear is likely the ballast trying to turn the lamp on.
If you need assistance with a new lamp, please feel free to contact us at or 866-764-5822.
Apr 12, 2009 | Mitsubishi WD-65731 65" HDTV
My tv is making a loud roaring noise in the back
I had the same problem, it was the color wheel (part # 270916). The bearings go and it starts making noise. It was fairly easy to replace.
Jan 16, 2009 | RCA HD50LPW175 50" HDTV
I have owned a Sony Grand Wega for about 3 years now and for the past few months the TV has been making a very loud noise. I thought the noise was the fan but came to find out it was not the fan and was...
There is a fan beside the lamp chamber in this TV. There should be 4 fans total, and the one beside the lamp chamber might be making some noise. They are all bearingless fans, so the noise should be relatively low-pitched "whirr" if it is the fan. If the noise is more of a buzzing sound, it could be coming from the lamp driver (ballast) or from the lamp itself. Lamps tend to do strange things toward the end of their life.
If you have never changed the lamp, it is about time. They have a 2.5 -3 year life span with average use.
One thing you can try is to turn the TV on from a cold start, and watch inside the vent areas beside the lamp chamber. If you hear the noise before you see the lamp light up, then it is probably a fan. If it starts as soon as you see the lamp light up, it is the lamp or ballast.
Hope this helps you...
Jan 06, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Loud noise when Tv comes on souns like fan.
The loud noise is the color wheel winding down when you turn the TV off. You need to replace the color wheel.
Nov 15, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Loud noise
I believe it is the color wheel. The motor might be going bad or it has dirt or dust in it.
I hope this helps
Nov 06, 2007 | Toshiba 62HM95 62" HDTV
RCA D44LPW134 44" HDTV Logo
242 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
