TV Combos
Problem for TV Combos
Generic problem for all TV Combos
Sharp TV won't turn on
By savi0027 on Oct 30, 2007
I got this free TV from my parents because it won't turn on after only two years.  When plugged in it makes a high pitched pulsating sound.  It took the back off to find out where it was comming from, it seems to be coming from the center of the circuit board.  I read somewhere that it might be a bad connetion with one of the diodes.  Is this something that i can do on my own?
Same Problem
Mar 13, 2009
-   when i plug in the tv, it makes a ticking sound. when i push the power button, there's no power. i opened the back cover to see where the ticking is coming from. i thought it might be the fuse but it wasn't.
as i listened closely where it was coming from, it sounds like it's coming from right center of the board at a square piece with yellow around it.
is this something i can fix myself? and where can i get this part?
thank you for your time.
Levi _ 901-592-7213.-   levia844
Jan 20, 2009
-   my tv wont turn on
-   Guest
Nov 28, 2008
-   Tv turns on then after running 5 minits or 2 hours it turns . some times it can be turned on other times it wiil not
Jack -   Guest
Solution #1
posted on Oct 30, 2007
Not Rated)
rushina
Rank: Master
Rating: 76%, 18 votes
if you dont have any experianc  dont try it on your own it will be better if you can find experts near your.the problem to your tv are power supply problem,there some transtors,fuse,diodes,check them,
Was this helpful?
Yes
No
Popular Solutions for TV Combos
Questions and Unsolved Problems for TV Combos
Answer
can i have the code for dvd1401tv for sky remote
Answer
i need an on off switch for my ldvd 1535 were can i get one
Answer
need 4 digit code for a magnavox-SDTV
Answer
I put in a dvd and it makes a clattering noise, I open it and the disc is spinning. Help!
Answer
Picture and sound gone tv bought for Christmas last year!!!!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For TV Combos:
Top TV Combo Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more TV Combo Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
