Home | Veo | Advanced Connect Personal Web Camera | When I plug in my cam...
Veo Advanced Connect Personal Web Camera
Problem for Veo Advanced Connect Personal Web Camera
When I plug in my cam the new device pop up comes
By nhoyos42 on Jun 13, 2009
when I plug in my cam the new device pop up comes up recognizing the cam but nothing comes up on my screen. .the blue light appears for a second and then it goes off .
when i go to skype and i click video calls it lightens up for a secon anthe it says to close all the applications where it is connected i dont see it connected any where else .i have a widows Xp i have the installation cd and is already installed what do i miss
thanks
Solution #1
posted on Sep 06, 2009
Not Rated)
FYmickydee
Rank: Guru
Rating: 88%, 165 votes
Expand the 'Imaging' folder in Device Manager and right click on your camera text - Update driver software using internet.
Test the webcam here by clicking on 'allow' in top window and assess picture in left hand panel.
If you can see a reasonable picture you know the hardware is OK (webcam - lead and USB )
Download this diagnostic tool and run it. Use > 'Next' until 'Finish'.
Address any issues found- dont worry about the first one - reboot webcam by disconnecting for a few seconds
http://www.download32.com/webcam-diagnostics-d35065.html
Was this helpful?
Yes
No
Solution #2
posted on Aug 31, 2009
Not Rated)
yooperbud
Rank: Wiz  Computer Accessories  Expert
Rating: 82%, 1924 votes
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
· Images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
After you get your camera installed properly, DO NOT unplug it from the USB port as it will cause
the drivers to be corrupt and render the camera unusable till reinstalled it properly.
Hope this helps. Bud
Was this helpful?
Yes
No
Popular Solutions for Veo Advanced Connect Personal
Questions and Unsolved Problems for Veo Advanced Connect Personal
Do you recommend Veo Advanced Connect Personal Web Camera?
Answer
Answer
i am brasilian...i need of the driver of the webcam veo advanced connect. Eu sou Brasileiro...eu... (More)
Answer
Are there drivers specifically for the Veo Stingray webcam. Attempted to download drivers, however,... (More)
Answer
i went to iso web sight didn't understand i need the driver info for web cam 642vs3cx
Answer
Hi, I have the Veo connect webcam but, i am unable to use it because i have windows Vista..I need to... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Veo Advanced Connect Personal...:
Top Web Camera Experts
Rank: Guru Guru
Solutions: 14193
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Web Camera Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
