Question about Panasonic PT-47WX49 47" Rear Projection Television
White outlines in HD mode
When I run my Panasonic PT-47WX49 with an HD input, I get white lines between certain shades -- usually appears like an outline of a color gradient or sometimes a shimmer across a field.  Kind of like a solarization effect.  This happens on my DVD player and my XBOX 360.  I have tried resetting the convergence and playing with all the on-screen picture adjustments.  Is there a way to fix this?
  • 126 Answers
Re: white outlines in HD mode
Is the screen control turned up to high if so you would see white lines on a dark picture
Posted on Feb 17, 2008
0 characters
3 Points
Panasonic PT-47WX49E blue convergence problem.
if convergence does not adjust in menu mode could be a defective convergenceic or fuse
Nov 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Horizontal Green Convergence line on PT-47WX49 is offset to the left 1-2" and can not be ajusted back. The center of the TV viewing picture is the only portion that appears normal.
you will need to replace the convergence ICs and feed resistors. You can get the convergence repair kit for your model at the following link. The kit contains the parts and a CD with the instructions on how to do the repair.
Jul 10, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Green outline really noticable around white objects like golf bal
Almost certainly you need the convergence IC's replaced. This is a big job you cannot do yourself.
Mar 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Convergence problem
If you cross reference this term, I think you'll find alot of helpful info on your problem:
Convergence amp ICs
These (there are probably two of them) are probably burned out, at least one of them. From what I see online in blogs and such, this repair can run several hundred dollars to have done professionally, but if you are qualified (or at least careful enough to learn how to do it SAFELY and CORRECTLY) you can do it youself for around $12 - $50, depending on what model part your set uses.
Hope this helps. I am about to embark on this same repair myself on my Panasonic PT47WX53G, so my best to you.
Dec 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
HDMI to DVI Picture problem
I found a user Manuel online
went to page 24
found that a setting that would skip this port when going through the TV/Video button menu.
To solve follow these steps - Menu -> Channels -> Other Adj. -> Input Lable -> digital - IN -> If set to skip change to what ever you want.
Dec 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Help problems with Panasonic PT-47WX49
Can you post a picture of what your screen looks like and I will try an assist you with the problem.
Aug 09, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX49 - Pink wavy horizontal lines
Try doing a reset of the TV first. On Panasonics this is done with the TV on and then pressing on the POWER and ACTION (on the fron of the TV only) buttons at the same time until the screen blanks out or a diagnostic screen appears. Once you do this all custom functions (color,tint,channel memory) will be back to factory defaults.
Feb 01, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 Convergence IC
usjavelin. I have the pdf files for the tv. I own the same one. I can send them to you if you'd like.
Dec 16, 2006 | Panasonic PT-47WX49 47" Rear Projection...
Widescreen thinks it's a big screen
Information as to the type of signal input is needed to resolve this problem. Does it appear in zoom mode when playing a dvd, or just in catv mode? Some times an HD cable box must be reset to a particular aspect ratio. This can be done by reading the owners manual of the cable box manufacturer. Scrivitron
Nov 19, 2006 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
74 people viewed this question
Top Panasonic Projection Televisions Experts
Jaime Hernandez
Josh Whitehead
Josh Whitehead
Are you a Panasonic Projection Television Expert? Answer questions, earn points and help others
