Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info
? 6:24
www.youtube.com/watch?v=7D0vUEDSwXo May 12, 2013 - Uploaded by Robert DIY
Replaced the crank sensor on this 2003 Jeep Grand Cherokee.... to replace my crankshaft position sensor on my 1998 grand cherokee laredo.
Oct 27, 2013 - Uploaded by WeekendHandymen
hi , do you think if I replace crank sensor will solve the problem ,my jeep .... Where's the crankshaft located in 99 jeep grand Cherokee laredo .
For 1994 Jeep Grand Cherokee 4WD 5.2L MFI 8cylthe Crankshaft Position Sensor is located under hood, center, rear engine area, passenger side of transmission bellhousing, mounted on bellhousing (click image for zoom)...
Fig. 5: Electronic engine control component locations-5.2L and 5.9L engines
Hope helps (remember to rate and comment this answer).
CRANKSHAFT POSITION SENSOR LOCATION FOR 4.0L ENGINE IS ON TRANSMISSION BELLHOUSING AT THE LEFT REAR OF THE ENGINE. FOR 5.2L ENGINE CRANKSHAFT SENSOR LOCATED ENGINE BLOCK BEHIND THE RIGHT CYLINDER HEAD.
The camshaft position sensor is located inside the distributor. It is a hall effect swich, simply remove the distributor cap and the rotor and you can lift it out, unplug and replace.
Have fun but beware a bad crankshaft position sensor can cause a false cam sensor code to be set sometimes.
Good luck.
patience
remove crankshaft pulley on 92 Jeep Cherokee
location of the crankshaft position sensor
4.0l
