Question about Sony KP-51HW40 51" Rear Projection Television
Red flash, then tv turns off
We are having this red flash problem as described, then the tv shuts off.
  • 3 more comments
  • dothompson Dec 17, 2007
    We think it was just an adjustment issue. We removed the front of the tv and adjusted the red gun and now it seems to be okay, at least for now. We think the problem arose when we moved the tv, throwing off the adjustment.
  • j j Dec 17, 2007
    happens @ once a week, sometimes while changing station, see bright red lines, then entire screen goes bright red and tv goes off. tried turning the pot on front for red to the left (1/16 - 1/8), but problem still persists. picture can look great at times, then appears to be losing "red", showing more green, as if hue setting is going off.
  • stressedmom Dec 18, 2007
    Have the same problem. Happened just days after my warranty expired. Call the repair man - told me it will cost $500 to repair. What is a red CRT? Should it cost this much to repair?
  • roger d Dec 22, 2007
    had same problem except tv flashes green them shuts off,had green crt removed and repaired at a cost of $ 500 and fix lasted for about 4 months and now it is doing it too good to throw away but can't put $500 into it every 4 mo.anyone know where i can find a new green crt for a sony kp-57hw40 57 inch tv approx 4 yrs old. roger .
  • mike_dixon Aug 28, 2008
    I've got the same issue with green. Been fighting it for about a year, but I can't seem to adjust my way out of it anymore. Tempted to fix it, but $500 seems a bit steep to be unsure of its future service when the new tvs are only another $1000-$1500 more...
  • 71 Answers
Red CRT defective. I have one brand new if you want to fix it.
Posted on Dec 06, 2007
My Samsung TV won't turn on
Please describe the problem more accurately. Flashing red usually means 'stand-by' state, flashing blue/green - starting up. When (during that) do you have a sound? Are there any 'high voltage' sounds like soft screeching from the screen? Is it LCD or LED?
Mar 02, 2015 | Samsung Televison & Video
I have a 55" sony
According to the manual (you can see it here) page 122 that describes 3 red flashing lights:
"The lamp cover is not attached securely. When you secure the lamp cover, the POWER / STANDBY light flashes in red and the LCD projection TV enters the standby mode (see page22)"
Page 22 says:
"... if the POWER / STANDBY light flashes continuously, this may indicate the display unit needs servicing..."
Most DLP displays make use of a "color wheel". These small motors spin at many thousands of RPM. They often begin to make scratching sounds when they are beginning to fail. Some manufacturers make it difficult to change yourself - and others make it pretty easy.
I hope this was at least a good starting point for you & good luck. Please rate my reply. Thank you.
Apr 04, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a 60' sony wega r60xbr1 i just had a new light engine installed last night the tv was never turned on afterwards . I turned it on the screen come on shut off imediatly the red led flashes 4 times...
LOOK IF YOURS IS A SONY I had a sony grand wega 60 inch with the same problem as many tv turns on shuts off the red led FLASHED 4 TIMES. it is a heating issue if one of the three fans inside are not turning when the tv is on even on the first few seconds of turning it on the tv will send a fault code of four flashes . Then the tv shuts off so it wont burn its self up or damage the optical block. all with this same problem of 4 flashes take a flashlite and make sure your fans are turning if not that is your 4 flash problem. I hope this helps someone and if it does i have done my job .
Dec 29, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Panasonic pt47wx52cf tv shut off and wont turn
Please count red light flashes and let me know. There would be long pause between flashes so count pause to pause. It is an error code of TV problem.
May 18, 2009 | Panasonic Televison & Video
Turn on pic turns red with thin bright red horizontal lines
Sorry to say, but that's usually the sign of a bad picture tube. One of the elements inside the tube shorts and you see the picture you describe, and the set shuts down due to high voltages getting to places it shouldn't. There's no solution except picture tube replacement, and that is uneconomical. You're better off replacing the TV when the tube goes bad.
Mar 31, 2009 | Toshiba Televison & Video
Immediately Shuts off with blinking light codes
I suggest doing a google search using the tv model # and brand.
I have learned myself that different big screen tvs seem to each have their own common problems. I have read before of power supply issues that cause what your describing.
Mar 11, 2009 | Samsung HL-R5078W 50" HDTV
It wont stop shutting off!
You can try the suggestion on the site I posted below. This site addresses a specific problem that tends to be fairly common in some Sony sets. Only try this if your sure that the problem your having is the same problem described in the site. Look at the picture of the screen on the site and see if that looks like your screen. The set on the site is red but it could be Green or Blue also. If you set won't stay on, you may have to turn the appropriate knob down slightly in order to get the set to stay on. Although he mentions this will fix a convergence problem, the fix described has nothing to do with convergence. The symptoms you are describing do not sound like a convergence issue. I am however a little concerned about the smell. Another thing is, after the set shuts off the Led will blink a code. For example it may flash 8 times then pause and repeat. You can Google this to find out more info on the problem. Many things can go wrong with TV's, I recommend you do as much research as you can to narrow it down. Good luck, here is the site.
Feb 26, 2009 | Sony KP-57HW40 57" Rear Projection...
My cinego shuts down
There are two fans on the right side. If one stops working, the Cinego will have the symptoms you have described. You need to send it in for repair. A local Radio Shack will tell you where to send it.
Dec 02, 2008 | Radio Shack Cinego D-1000 Multimedia...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
138 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
