Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Motorcraft alternator to regulator
Took off alterator regulator in side . want to put on alter- with out side regualator. alter- has a tbattery terminal im ok with that &stator terminal not sure where this goes on regulator has field post im ok with that. putting all this on a new holland skid loader . its a 1979 ford alternator ®ulator has 3- post bat-&gen-&field . & need to know what wires go to switch for charging batt.                  thank you mike
  • 328 Answers
Here is a generic wiring diagram that should work
Posted on Oct 30, 2007
  • Victor Hugo Leon Cevallos
I have a 05 2.7l XL7 just put a new alternator in it today was charging at 14.32 now it's charging at 12.30v I'm trying to find the relay for it to test it where is it at
the relay will not alter the charge rate but the voltage regulator will
regulators reduce the rate of charge according to the battery voltage so if the battery is fully charged at 13.2 volts it is possible that at idle speed , that voltage recorded from the alternator is correct
you can check by inducing a discharge such as turning on the head lights and ac unit and then increasing the rpms to around 2000rpms where alternators are checked
Jun 26, 2017 | Cars & Trucks
83 olds car doors,will not close on one side,the other won't open or close
doors do not alter in their openings unless the following has occurred
accident that alters the door opening shape or alters the door hinge position
badly worn hinges
people hanging off open doors or lastly
the sill panels ( rocker panels ) under the door that are part of the door opening and body strength have rusted away under the car allowing the door opening to alter and affect the doors closing properly
Oct 19, 2015 | Cars & Trucks
HOW TO REPLACE 2002 ford escort zx2 alternator
Alternator Removal and Installation
  1. Disconnect the battery ground cable.
  2. Remove the drive belt.
  3. Remove the coolant tank reservoir.
  4. Disconnect the two electrical connectors.
  5. Remove the alterator bolts and position the alternator aside.
  6. Remove the alterator.
  7. Remove the battery power nut and washer.
  8. Disconnect the battery positive cable and remove the alterator.
  1. To install, reverse the removal procedure.
Feb 27, 2015 | 2002 Ford Escort
Where is the voltage regulator on 1999 Honda Passport
regulator for the alternator is in side it. faulty regulator may also be the hole alternator at fault blinking battery light is bushes going on full when started can be a bad wire on the return on altinater or failed altinator.
Sep 28, 2013 | Honda Cars & Trucks
I have a 2000 hyndi elantra, I replaced the serpintine belt and thought that was the problem. But I drove it abt 3 miles and it just died; I had to pull off to rd side and got a jump, made it a littl
sound like the alter belt or the alternotor itself needs to be replace to go the cheap way first i would have my battery tested and to check the alter yourself do this easy test start the car with the car running remove the postive battery cable off the battery if the car stay running then the altern is good if it shut down you need a new alter good luck
Jan 14, 2013 | 2000 Hyundai Elantra
Alterator on 2000 mercury cougar putting out almost 17v
Yes it could have a bad or busted wire some where gonna have to ohm it out
Nov 30, 2012 | 2000 Mercury Cougar
What will make the alterator on 1988 honda accord not charge is it a fuse but the fuses are good
the alternator may be faulty or it may be the voltage regulator is faulty, you may have to take the vehicle to an auto electrician to have the charging system tested.......cheers
Aug 27, 2011 | 1988 Honda Accord 4 Door
I need to change my region code to Europe How do i do that?
The device manufacturer predetermines the available setting from which adjustments are achievable elsewhere from factory. First, once a device is acquired from the market, an initial installation has default settings that are capable of alterations with conditions. Products manufacturer for the American market would usually have for regional settings the fifty main land states to include territories at which availability become possible. For example, devices may have for regional settings east coast, west coast, mid western states, and southern states as choice settings capable of alterations. However, device intended for the American market may least have regional alteration feature capabilities. The default regional settings may have been the devices only available settings. Alternately, device may simply disallow settings like with those without any regional adjustment features. Exploring through the device menu buttons should make available any manufacturers embedded setting capable of manufacturer's alterations. If any settings are found on the device, refer to the user guide for step by step instructions on achieving alterations.
Jan 21, 2011 | Canon MP640 All-In-One InkJet Printer
Alternator not charging batt.
inspect cables, they break down over time, corrode and turn green inside
Nov 25, 2008 | 1988 Lincoln Continental
Battery runs down after driving vehicle
Sounds like you need an alternator. Start the car and hook a volt meter to the battery. If it is not charging over 13.8 volts it's alternator time. Thanks....Dan
Jul 27, 2008 | 1997 Chevrolet Camaro
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
6,685 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
