Question about SanDisk Sansa e200 MP3 Player
My sansa wont turn on, I took out battery to reset and blue ring
My SanDisk Sansa 6.0gb wont turn on, I took out battery to reset and blue ring only lights up. Any help would be appreciated .
  • djburmis Jun 15, 2009
    pc dont recognize it now
  • 44 Answers
Try resetting your firmware via Sandisk's support site. If it still doesn't work, your sansa's mainboard might be busted. The cost of replacing it will be more than a refurbished one (under $40 online).
Posted on Jun 14, 2009
SOURCE:
My Sansa e200 series is stuck on the splash screen and would not response on any or cannot be recognized by computer. Please assist
Battery and Black screen Blue ring: Remove the back and check and see if the battery isn't fully connected
I put a folded peace of paper and put it on top of the battery also push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screen, Black screen Blue ring ) and put the back on.
Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard thIs should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize IF not try a laptop.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
RESET: Go into the settings and scroll down to reset all, push center button, scroll to yes, push center this will restore factory settings.....
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.
This is what it states in the manual for the 260 sansa Page 29
Recovery Mode also resets system settings when unplugged...
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa. http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related here is a link to a kid showing you how to goto recovery mode.
Update software from this link..
and install the software before you recover
Jun 27, 2010 | SanDisk Sansa e250 MP3 Player
STEP 1 – Reset the device
  1. Slide the Power switch up and hold it for approximately 20 seconds.
  2. Release the Power switch once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater.
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
this is their instructions not mine, but i hope this helps you.
Aug 20, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e280 wont turn on
What i do is drop it not hard but a light drop and it should turn on than
Aug 25, 2008 | SanDisk Sansa E280 MP3 Player
Sansa went "dead"
Try holding the power button down for at least 10 to 15 seconds. That should turn it off. Turn it back on. If this doesn't work, try taking the battery out for a few seconds. If it still comes up with only the blue ring on, called Sandisk tech support to try to get an RMA. The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Apr 03, 2008 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa e250 MP3 Player wont turn on and isn't detected by computer.
your battery could be dead. but when you plug it in does the blue ring light up
Jan 26, 2008 | SanDisk Sansa e250 MP3 Player
Sansa 2.0 mp3
Key lock means the HOLD switch is on.
Slide it the other way.
Best of Luck.
Nov 27, 2007 | SanDisk Sansa c150 MP3 Player
The Screen Stays black and the ring turns blue and thats it
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
192 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
