Question about i-mate K-jam Smartphone
On button not switching on device (battery charged)
Tried hard reset but no response
Kindle fire will not charge-got a new charger and it still will not charge- does it need anew battery and how do I do that?
The Kindle touch and the Kindle FIre are great devices for your reading needs. However, there are times when it becomes unresponsive and freezes on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If theKindle still has issues, then try the steps below on how to reset your Kindle touch/fire. Please note that you may lose your data during the reset process, make sure you have made a backup of your files before proceding.
  • Hard and soft reset
    Make sure the Kindle is turned ON.
  • Press the Power button for 20-30 seconds until it turns OFF.
  • Wait for it to reboot, if it doesn't press the power button to turn it ON.
  • Your kindle should be back to a responsive state.
  • this might help you.
Dec 22, 2014 | Amazon Kindle Fire HD
My kindle is frozen it wont let me search for new books
The Kindle touch and the Kindle FIre are great devices for you reading needs. However, there are time when it becomes unresponsive and freeze on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If theKindle still has issues, then try the steps below on how to reset your Kindle touch. Please note that you may lose you data during the reset process, make sure you have made a backup of your files before proceding.
Hard and Soft Reset
  • Make sure the Kindle is turned ON.
  • Your kindle should be back to a responsive state. hope this helps
Dec 22, 2014 | Amazon Kindle Wireless Reading Device
My Htc Chacha's lcd light keeps flickering on & off it wont charge what does that mean ?
Sindia, this sound me software problem, when your device has a software problem it wont charge or start at all normally, so try to hard reset but this will delete all data for hard reset follow the instruction :
1. Switch off device;
2. After 3 min, Press and hold volume down button and power on button once it shows 3 android images appear leave the buttons and press volume down to select a clear storage, and then press power and then press volume up to start the factory reset. after this process your device wil reboot and start normally. now your device is ready to use. Best of Luck.for further help post comments.
Source :
http://www.hard-reset.com/htc-chacha-hard-reset.html
Jul 13, 2012 | HTC Chacha Smartphone
I put the 305 on the charger at night and I see the charging in progress message. When I wake up it is blank and the unit will not power up? It's like the battery is dead and it won't respond to the...
Over charging sometimes does that effect.
However, best is reset the device. Try soft reset first, if not sufficient, try hard reset.
Soft reset : Hold mode and lap/reset for 10 seconds, then release.
Hold start button then for 10 seconds, device should restart.
Hard reset : Hold mode and start button. 10seconds after, still holding them, pulse press lap/reset button, then release all.
You should get a screen asking to confirm reset to factory settings. You'll loose all data by this, but device should restart with normal behavior.
Sep 26, 2010 | Garmin Forerunner 305 GPS Receiver
My Treo 700p won't turn on. Even with battery fully charged. How do I reset it?
there is a hard reset button under the battery cover on the side where the stylus goes. it should be able to restart your device fully and completely, is some cases you may need to leave the battery in and charging for at least a day or even use a friend's battery , because some glitch certain devices just refuse to boot and also to charge the battery if they somehow recognize the battery then in my case I use my wife's treo battery to be able to get mine jumpstarted. whenever I experienced this after a while I was able to switch back to the original battery and then the device was finally charging that one. weird but true, so we switched to android based devices since. but I remember this issue clearly.
Jan 13, 2010 | Palm Treo 700p Smartphone
The PC is not switching on
Hi. I assume that you plugged in your original battery after it was out a while. When your device's battery is drained, all the data in your device may be resetted (changes according to your backup battery's condition). So you should first try to plug it into AC power source for a couple of hours without touching it (Let the battery become usable enough). Then, your device should open without any error, but it may take a while because it will install the Operating System from ROM. In most cases, pluging out your battery won't destroy any internal parts of your device, it may just reset it to factory default settings. If there is an error, here is how you can hard reset your device:
HP iPAQ rx3715 Hard Reset:
1. Hold down the Mobile Media button (on the far left) and the iTask button.
2. Then press down the reset button with the styles for a few seconds until the screen goes dark.
3. To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Hope this helps.
May 31, 2009 | HP iPAQ RX3715 Pocket PC
No power When I press power button.- Battery is full
Try changing ur battery if it doesnt help then do this
try pressing the reset button near the charging port on the pda if it doesnt work try to hard reset it as follows
try this if it helps
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest Rom update downlaod and update
other wise check xda forums for software dead HTC http://forum.xda-developers.com/
pls do rate me if i fixed ur problem
Feb 24, 2009 | HTC Touch P3450 Smartphone
Compaq V5201US Notebook Will Not Start/Boot UP
Remove the power adapter and the battery. Hold the power button in for up to 60 seconds to discharge the laptop. Re-apply power and try booting the laptop.
Jul 20, 2008 | Computers & Internet
GARMIN c550 will not turn on
There is an ISSUE with the DEAD ZUMO, however some of the are solved, and some need to be shipped back.
There are a couple of options.
1) remove the battery, keep power button pressed for a few minutes. install battery, try.
2) fully recharge the battery with the wall charger, try
3) With a fully charged battery, press and hold the + button and press the power button(hard reset).
4) hold thumb firmly on top left of touch screen and hold power button till it switches on(hard reset).
5) Try a different battery (fully charged)
6) Ship it to Garmin
Sep 08, 2007 | Garmin zumo 550 GPS Receiver
PDA is totally black; not charging
The easiest solutions are easily overlooked. 1. Check your charger; a cheap multimeter will do for the voltage check. If the voltage (dc) written on the back of the charger is what you get at the plug, go to (2),if not, change your charger,problem solved. 2.You either have a messed up screen or battery. 3. Check the voltage at your battery terminals after charging the battery for like 1hr. If you do not get a resonable read; 2-5v ,just trash the battery and head for the nearest shop to get a fresh one.In case your battery reads okay,your screen or worse, one of the components on the board of the set has gone kaput.
Nov 14, 2006 | Palm Zire 71 Handheld
i-mate K-jam Smartphone Logo
22 people viewed this question
Top i-mate Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
