Question about Maytag MAH8700A Front Load Washer
Maytag atlantis top load washer
It smells moldy.  I HAVE RUN IT WITH BLEACH IN IT, ALSO VINIGAR.  sTILL SMELLS.  SHOULD I TRY TO TAKE AT AGITATOR OUT?  OR WILL IT AL FALL APART IF I TAKE THE SCREW OUT.  THE SCREW IS DOWN 4 1/2 INCHES & I DON'T HAVE THAT KIND OF SCREW DRIVER.  SO IT IS A LOT OF BOTHER.  WOULD THAT HELP?
    Problem Solver:
  • 7 Answers
There is a new product on the market call affresh that works wonders with that nasty mold smell
check it out http://www.affresh.com/home.jsp
Posted on Nov 07, 2007
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
My Maytag Neptune front loader always retains water after the rinsing cycle is complete. This has lead to mold in the door gasket and a moldy smell. Is it normal for water to stay in the machine after the...
pump is probably clogged not allowing all water to drain out. Should never see water in the tub at the end of a cycle. About once a month you should run your washer through a cycle with hot water and bleach. Doing that should keep the moldy smell down.
Mar 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune TL has a moldy smell that I can't seem to get rid of. I've used a steam cleaner to blast away mold I've found around the rim and other parts I can reach, and I've run cycles of just hot...
Take off the round agitators one at a time, by popping off the center cap and use a hex driver to remove the screw. Tilt out aggitator, and clean back of agitator, hyousing and gear box of the moldy/mildew build up..its kinda gross. That is where the stink comes from.
Jul 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag washer has a defect, technican told me, that lets water get between the tub and outer lining and sit there and stagnate smelling terrible.
The water always goes from the tub to the outer shell, that is where the pump connects. Put a little bleach in the tub with some water, shake the agitator side to side to move the drum enough to circulate the bleach around the tub. Then pump the water out and then lower the hose down to a bucket to get the last of the water out. Feel around between the inner and outer drums for anything that has jumped out of the inner tub to the outer drum. You should be able to push the inner drum aside enough to get your arm in. You may have to open the top to get your arm in the space.
http://www.pcappliancerepair.com/model-display.php Check this site for your machine.
May 07, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Moldy smell
try running it throgh a cycle with nothing but hot water and bleach let set for a couple of minutes between cycles with water in it may have to do a couple of times
Mar 29, 2009 | Whirlpool LSB6200KQ Top Load Washer
Mold and smell from Maytag washer
The mold will be growing in the upper parts of the agitator basket above the water line. Spray these areas with a bleach/water mixture using a spray bottle. Turn off the hot water valve to your washer. Disconnect the hose connected to this valve. Connect a leak free garden hose to the valve. Connect a garden sprayer to the other end of the garden hose. Turn the hot water valve back on. Check for leaks. Use the garden sprayer to rinse and remove the mold. Be careful to keep all of the water in the agitator basket. Turn off the hot water valve. Reconnect the hose from the washer to this valve. Turn the hot water valve back on. Check for leaks. Run a wash cycle with an empty load.
Jan 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis black oil like residue and can't remove agitator
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
this is a very common happening and it means
This usually means that a seal is degrading or dissolving.
This washer is a top loader, Right!
I believe it calls for HE ( High Efficient) laundry detergent.
If we use to much of either it will cause this !
This usually happens due to using to much detergent or bleach.
You said, Black oil like residue discharged from washer during use. Stain clothes, almost impossible to remove. Loosened nut on agitator but it will not budge, and am afraid of damage if I try to pry between agitator and bottom of drum.
Please remember to leave a rating before you go!
Thank you
Sep 20, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Mouldy mildew smell
I had the same problem and I fixed it fairly easily in about 45 minutes:
The root-cause is the incredibly stupid design of the plastic ring that snaps over the plastic wash tub. It is filled with many nooks and crannies that rarely contact the wash water, thus getting scummed up and moldy. See a picture of the gross mess here: http://www.falselaborblog.com/2008/08/moldy-maytag.html
The fix involves opening the top (easy) and removing the ring (fairly easy) and can be done yourself if you are the least bit handy.
Unplug the unit.
***If you are mold-sensitive, wear gloves and breathing apparatus or have someone do this for you.***
Tape the lid shut so it doesn't flop open when you raise the lid.
Use a putty knife to push into the front seam about 1 1/2 inch from each corner. This unlocks the top and it will open just like the hood on a car. Carefully secure this in the open position and don't let it fall on your head or your hands.
You will see plastic fasteners holding the top ring around the outer plastic wash tub. These will unsnap (you may need a flat-head screwdriver for some of them).
Carefully lift this out and try not to puke when you look at the underside (see photo http://www.falselaborblog.com/2008/08/moldy-maytag.html). Take it to a laundry tub or bathtub and thoroughly clean it by scrubbing with hot water, detergent and bleach.
Before replacing the ring, use a thin brush to clean between the upper part of the wash tub and drum---the scum and mold will be in here also.
Replace the ring in the reverse of the above steps.
Prevention: There is none. You will have to do this every 4 to 6 months to prevent mold from infesting all of your clothing, etc.
I'm experimenting with limiting wash load size to "large" and never using "super", reserving the "super" setting for running periodic (hot water + Clorox) to see if it reaches the idiotic upper ring and keeps it clean. I am not hopeful that this will eliminate the need for these overhauls.
P.S.: The person that designed this washer should have all of his/her underwear and bed linens washed in an uncleaned Maytag Atlantis for life.
Aug 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag MAH8700A Front Load Washer Logo
108 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
