Question about Sony Walkman MZ-R55 Personal MiniDisc Player
Problem w/ recording
The LCD keeps displaying PROTECTED when I try to record. This has never happened before. The protection tab on the minidisc is not engaged, the HOLD switch is not engaged and the minidiscs are recordable. Any other troubleshooting ideas?
4 Suggested Answers
  • 27 Answers
SOURCE: Erasing a used minidisc w/out software
While holding down the Pause button, push Record. The display should blink the disc icon and REC. Then push the <<| until the display shows 001. Then push the pause button to start recording. This will start it from the beginning. You can use this feature to start recording at the beginning of any track you choose. You can download a manual for this machine at:
I hope this helps.
Posted on Feb 27, 2008
SOURCE: how to music on my minidisc recorder mz-s1
quiero pasar musica de casette a mi mini disc como le ago
Posted on Jan 27, 2009
  • 3006 Answers
SOURCE: Issues downloading audio files from Sony minidisc to my computer
You can't. You can only transfer digital files from your pc to your Minidisc player., it's a one way street. there's no hack for it either as it's a basic hardware issue within the player itself.
If you want to download from the player to the pc you'll have to connect the audio output to your pc and record it the old-fashioned way which loses a bit of quality. All Minidisc compliant players were like this until the advent of the Hi MD format which succeeded the Net MD's as an anti-piracy measure.
Posted on Jul 05, 2009
  • 10594 Answers
SOURCE: where can i get an user manual for a sony walkman
Click Sony Support to download user manual copy of MZ-N710
and if need further info, click Sony Support UK
Posted on Dec 13, 2009
Testimonial: "excellent solution thank you"
0 characters
1 Points
My minidisc recorder is showing 'protected' message when I try to record. Minidisc is blank and new. Problem is not with the write protection tab.Any suggestions please?
There are only two possibilities - there IS something wrong with your write-protect tab (try opening and closing it once), or there is something wrong with the little arm that reads the tab (perhaps it got bent).
What happens if you use a different disc?
Aug 08, 2013 | Personal MiniDisc Players
MZ-G755: No sound recorded to minidisc after about 40 mins of recording
Try to use the manual probably causing no sound is the way how you recorded the sounds. Possible wrong settings you set the minidisc check the manual click below
Nov 21, 2007 | Sony Walkman MZ-G755 Personal MiniDisc...
Pc minidisk
Google sharp MD-MT280E and download the Users Manual.
Aug 08, 2013 | Sharp MDMT280E Personal MiniDisc Player
Doesn' let me record
check the sliding door on the front of the minidisc. If its not open, then it should record IF you didn't record using the computer.
Oct 27, 2008 | Sony Walkman MZ-R700 Personal MiniDisc...
Net md walkman mz-n510 can't transfer from md to pc
i have same problem. maybe the tracks on the minidisk were not transferred from the same computer, as in I bought some disks that were already full, but my computer said error when I tried to delete.
Jun 29, 2008 | Sony Net MD Walkman MZ-N510 MiniDisc...
Sharp MD-MS702 Minidisc recorder - no audio from 3.5 mm output jack...
the solution which seems to have worked for most people is to take the unit apart and make sure that the ribbon cables inside the unit are all attached properly.
Apr 30, 2008 | Sharp MD-MS702 Personal MiniDisc Player
Write protection
Did you record the material using SonicStage or a USB connection? If you did, you will have to erase this material using the same program. You won't be able to do it with the MD.
Mar 19, 2008 | Sony Net MD Walkman MZ-N510 MiniDisc...
Sony Walkman MZ-R55 Personal MiniDisc Player Logo
Top Sony Personal MiniDisc Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Sony Personal MiniDisc Player Expert? Answer questions, earn points and help others
