Question about Refrigerators
Defrost problem with GE Monogram ZISS48DAASS 48 inch side by side
Hi, one day I noticed that the ice tray was frozen in place, and ice would not dispense. I was able to open the door and melt the ice freezing everything together with a heat gun on low setting. Since soft ice has been caused before by dirty coils, I vacuumed the condenser coils on the top of the unit. These seem to get dirty faster due to the type of condenser coils (looks more like an automotive unit). I put everything back in and expected for the problem to be solved. However, I an still getting ice sickles forming, that make it down to the ice make dispenser and freeze all the rotating components in the door dispenser together.
After further poking around on the web, it looks as if there is something wrong with the defrost system: 1) drain tube clogged. I don?t see any water in the tray. In this unit (ZIS48DAAS), the drain tube runs horizontal across the top to a pan just under the compressor. The tube looks clear, but I guess the obstruction could be in the entry which I can?t quite see since it is in the evaporator box. 2) The drain trough heater is faulty. It seems like I would not be getting ice sickles from running water if the defrost heater was bad since there wouldn?t be anything to defrost the evaporator to turn the frost into a liquid. From the wiring diagram, it looks as if the control circuit for the defrost heater also runs the fill tube heater, and the drain trough heater, so I am assuming the defrost thermostat and defrost control are working.
So my first guess is that maybe the drain trough heater is bad, or the tube is clogged. It seems like if I unplugged the unit, and blew warm air from say a hair dryer into the evaporator box, that water should drain thru the drain tube into the pan below the compressor. If I can figure out where the connectors are, I might be able to check the resistance on the drain trough heater. It looks like it is supposed to be 338 ohms.
The three heating elements look to be in parallel with the following resistances:
Fill tube heater=3412 ohms, defrost heater=38 ohms, and drain trough heater 338 ohms. So if I can find the correct place to check the resistance, it seems like I could use my parallel resistor law and figure out if anyone of them is bad. Since the ice maker works, I think I can assume the 3412 ohm resistor is good. If the resistance is 307 ohms, then it seems like the defrost heater is bad. If the drain trough heater is bad the resistance will be just under 38 ohms, maybe 37.5, fill tube heater is bad then the resistance should be about 34.2 ohms. Everything good, the resistance should be about 33.8. Sounds good in theory, but I am not accounting for tolerances in the resistive elements. However, I hope that my ohm meter could at least pick out a bad drain trough heater.
Before I do something stupid, any thoughts about my analysis, or any better suggestions?
Re: Defrost problem with GE Monogram ZISS48DAASS 48 inch...
I have ge monogram POS model zisw 42. Had the same problem. Poor design is the issue. Drain tube exits the case of the exchanger, is strapped to top of frig box, then up and over the pullout glides for the compressor. Water has a hard time running up hill. Stuff collects in the tub and blockage and or major restriction occur.
GE fix: replace defrost timeer to run longer,( so much for energy savings...nothing like runnig a heater full time in a freezer to keep ice cream soft) replace ss heater tray with one made of AL to conduct more heat. This fix worked for a while, then problem reappeared.
MY fix: Buy 2, 90 degree 1/2 inch fish hook style elbos, gray in color, at the local hardware store..see where PVC fitting are kept, Cost was less $5.00. Plus about 12 feet of 1/2 inch clear tube...about $6.00. go back home. Cut drain tube at top of box at about where it was attached, mid way between the pullout tray with the copressure and where it exits the freezer/exchanger box. Fit one elbo, point to the rear, add new clear line long enough to exit the rear of the frig case. Add 2nd elbo, pointed down, keep it close to the back of the frig. Add additional clear line to chase the drain line down through floor or wall such that the drain tub is now dripping it's waste water (very small amount really and under no pressure) outside the house. This fix has worked for about 10 years.
Posted on Aug 11, 2009
Yep, the drain tube is "iced up" and formed a plug of ice which is preventing the water from the defrosting cycle from exiting the defrost pan and exit to the pan under the compressor. The heat from the compressor will evaporate this water.
It looks like the compress can slide out to access the drain tube but I can not figure out how to remove the grill. So, I go into the freezer compartment and remove the panels to expose the heated drain pan. This is a small hose clamp that hold the drain tube to the drain pan. Once you remove the pan you can either use a dryvac to **** out the ice plug or do what someone else suggested and cut a ****/hole in the drain line from above. I used this method to push the plug out.
A service tech told me that the drain plug will freeze up when the line get dirty. The first time I did this, there was a lot of dirt inside the tube.
Posted on Apr 15, 2009
0 characters
3 Points
I have a GE Monogram ziss48daass 48" side by side that appears to have a compressor problem. With the upper decorative panel removed, the refrigerator cools OK, but he compressor case temp is 219 degrees...
Make sure the condenser fan is working and the condenser coils are clean. The temperatures are very hot but this could be because there is no air flowing through the condenser coils,
Aug 15, 2014 | Refrigerators
Ge Monogram side by side refrigerator ZFSB25DMDSS will not dispense the ice. How do I fix it?
hi.ill assume u have ice but not dispensing through when u ASK.1-check ice bucket and make sure the ice is not frozen solid and jamming the motor.if ok there then it will need to be checked for for power supply to motor.could be switch/motor/module.wire brake or corroded.hope this helps.good luck .Ali
Jun 24, 2012 | GE Monogram Side by Side Refrigerator
Hi My GE Monogram Fridge isn't cooling very fast. It takes forever for it to get to 37 F. The freezer works fine. I have noticed frost build up in the fridge (not freezer) near the back (there is a vent...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 01, 2011 | GE Monogram ZFSB26DRSS Stainless...
GE Monogram ZISW36DYA ... frozen ice-cycle rivulets run down both sides of freezer (water off for days to verify it is not ice maker) ... defrost control clicks when rotated and advances with time ... do...
Seems to me that might be a clogged defrost drain or maybe a dripping water valve. Doing that. I have the service manual with nice pictures in it that show clearly how to access the components.
Nov 10, 2010 | GE Monogram Side by Side Refrigerator
I have a monogram zis 42d side by side the freezer section works but in the defrost mode the unfrozen ice runs down the sides of freezer and into ice cube storage container, I have cleaned out the drain...
I have this same problem. Now, the freezer will not get cold enough, but still water runs down into the ice bin and just turns into a big solid block of ice. The water is dripping from the top of the freezer compartment. I have disconnected the water coming to the refrig to not allow it to make ice, but still happening. Please post if you have found a solution? Defroster issues?
Nov 09, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Ice maker will not dump ice there is ice in "tray" but wont dump
I.M 6 electronic Ice makers are non servicable, replace the ice maker. throw the other in the trash can.
If ice is in the ice maker then you know it got water but didnt dump the ice. its the ice maker.
Oct 26, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Intermittent rattling noise in refrigerator
Do you have an ice maker? That noise could be the ice maker trying unsuccessfully to dump ice, usually caused by a defective heater to loosen the ice cubes prior to dumping them into the container.
Possibly even if your ice maker appears to be functioning normally, it may be attempting to dump ice several times before the ice is actually ejected and if you don't use a lot of ice, you'd never notice it.
Hope this helps.
Jun 27, 2009 | GE Monogram Refrigerator Built-In...
There are a few reasons why the refrigerator part will not are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Jun 24, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
No ice
most quality refridgerators have a heater coil about the drain. either no poweror coil is open.
Apr 17, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Refrigerators Logo
3,189 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
