Question about Philips 19PR19 19" TV
Philips magavox model 19pr15
I'm having vertical problem at bottom i'ts missing about two inches at bottom every thing else work's perfect. i resoldered  the vertical TDA7052B Found about 5 caps low esr changed them but still have the problem. I want to know if this model has a code that i could enter to adjust vertical. or just change the vertical ic.
  • ginoe Nov 07, 2007
    yesterday I wrote a comment . that sad that i enter the sub menu. but instead of hitting the reply i hit the accept . but thats ok .the problem was a currupt eeprom. i could not find the original st24w04-6. so i put in 24c02-6. everything works but doesn't show the channel when i change the channel button. can you please help.
  • 140 Answers
1. To enter the Service Alignment Mode (SAM), press the following key sequence on the remote control transmitter: 0-6-2-5-9-6-Status.
2. From the top level SAM menu, use the Menu Up/Down keys to highlight the Geometry sub menu.
3. Use the Menu Left/Right keys to enter the Geometry sub menu.
4. In the Geometry sub-menu, use the Menu Up/Down buttons to select VAM.
5. Using the Menu Left/Right keys, adjust VSH so that the horizontal bar is properly centered, top to bottom.
6. Using the cursor up/down keys, select VAM from the Geometry sub-menu, and use the Menu Right key to
increase the value to obtain a slight overscan.
7. If other Geometry adjustments are needed, proceed to the necessary adjustment using the Menu Up/Down
8. Upon completion of Geometry adjustments, press the Menu button to return to the top level SAM menu.
9. To exit the Service Alignment Mode, turn the set off with the Power button on the remote control.
Posted on Oct 30, 2007
Smartimage problem on screen
Just hold the smart image button (last on left side of display)
I had same problem a second ago, so it worked for me.
Apr 14, 2010 | Philips 220CW8FB 22" LCD Monitor
Check speaker. Audio circuit. Mute signal
Apr 01, 2010 | Televison & Video
I have a magnavox tv model # 27MY6005D/37. Where can I get an owners manual and I have a line two inches on top like the tv bottom is on the top. How can I adjust that? Thank you
According to the model# you have a 27 inch TV so this would mean you have a bad capacitor in the vertical circuit 100uf 35v and you may need to replace vertical IC as well.Call Mats for parts 1-800-628-1118 for owners manual try Encompass Parts 1-800-638-3328.Somtimes if picture pops back to normal then resolder Vertical IC but if thats not happening, replace parts.
Nov 17, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have the same model 37MF321D/37 and the Blinking Light
I fixed it by replacing the two capacitors with 3300uf 25v instead of Magnavox's 3300uf 10v and a power swith that I ordered from Also I did have a power supply put in from a repair place that cost $160.00. It is working perfect now and no blinking light.
Sep 20, 2009 | Philips Magnavox 42MF521D/37 Television
Black vertical bar about 4 and a half inches wide down center of screen
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Control of vertical TV image projected on the screen
You can try looking for 2 things
1. A button on your remote that says either: ARC, Ratio, 16:9, 4:3.... Some remotes have a picture of a square with arrows pointing out towards each corner..... I'm unfamiliar with this set, but it sounds like a widescreen, so give it a go
Apr 22, 2009 | Televison & Video
Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Sep 10, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Magnavox model rs2745 date code 3812u102d
You must be using an he016 with the only difference being one extra function "CD". The following link is a user manual for PM525S, very similar and may help you out.
Jun 08, 2008 | Philips Magnavox REM-350 Remote Control
Convergence problem as described by others like Avil.
This would be your vertical, now what parts are you talking about?
Dec 22, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 19PR19 19" TV Logo
434 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
