You can try 4Card Recovery. It is freeware and very helpful. Detailed steps are here. And it's quite easy.
Step1. Download 4Card Recovery on your computer and launch it.
Step2. Select the files that you want to recover, or you can choose to recover all.
Step3. Choose the 'next' button to scan it and just wait for about ten minutes.
Step4. Keep your recovered data or files on other part, this is very important.
How to Recover Photos Videos off SD Card after Formatting Unformat SD...
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
