Starts to fill up the water in the first cycle and then it stops!
SOURCE: Starts to fill and then stops, and the cycle continues on.
Jmars, under the consol there is two pressure switches. One controls the fill and the other is back-up incase the other fails. It sounds like your water pressure switch is tripping too soon. Try putting the washer into a self test mode by pressing in this order soak--soil level---soak--soil level. The machine should enter a test mode. Let it run it's test and see if you come up with any error codes. The pressure switch is the one on the left under the consol. It will be marked OPR, the part number is 8054766. The consol will lift up by using a putty knife under each end, pushin on the clips and lifting up. The back panel of the consol is removable. Catriver..post back
SOURCE: my washer won't stop filling
I have a Maytag that had that problem. Mine has a plastic tube inside of the machine that connects to a sensor. As the water level rises, some of it goes into this tube creating air pressure on a sensor that signals the machine that the water is at the selected level. The bottom of the tube had come loose and just needed to be put back onto the fitting. I accessed this tube by lifting the top of the machine, and it is in the back. Very easy to get at. I hope this works for you.
SOURCE: Frigidaire Affinity Atf7000e...Does not load up water.
clean your inlet screen...onthejob...take hose off and take screens out of inlet water vavle and clean then replace..onthejob
