Question about Braun Syncro 7526 Electric Shaver
Switch not working properly
Shaver turns on but neither of the other options works.  How do I disassemble the shaver to repair the switch?
  • 3 Answers
Managed to fix it - actually was a 7680. Only do this if you:
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd displaySwitch not working properly - 1.gif
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
Posted on Jan 28, 2008
Power button broken on Norelco 7825xl shaver - Can't turn on... Button has actually fallen back into the shaver itself, and can no longer be reached to depress - to turn on or off. Help... i love this...
The specific part you need is no longer available. However, the part linked here at will work with your model also. The entire switch button is included. The light display just wont work properly
Philips Norelco Front Body Housing with Switch Button for Quadra 7865XL
Jul 12, 2016 | Norelco Health & Beauty
I have a Braun 7680, and the switch won't work - it is stuck on "on".
Most likely, the mechanism is broken and will need replaced. The switch is part of the trimmer assembly which comes attached to the outer casing. You will find a replacement at See link below
You will also find disassembly tutorial at the link below
Nov 17, 2010 | Braun 360° Complete 8985 Electric Shaver
Norelco shaver doesn't recharge.
If the shaver won't hold a charge it usually means that the batteries need replacement. This requires disassembly and soldering skills. It's not hard to do but if you're not handy with a soldering iron a shaver repair shop can do the work for you. However, if you have to pay to have it done and if the blades are more than two years old and need replacement, you might be better off just buying a new shaver.
Jul 05, 2010 | Norelco Cool Skin 7775X Electric Shaver
The on/off mechanism on my dads braun 6520 is stuck. It won't turn on.
Hello running girl, Have you looked to see if maybe the "lock-off" feature hasn't been engaged?
If you look at the razor, right above the on/off and sideburn trimmer selector, you should see a full bar that goes all the way across the shaver. Push this up toward the shaving head to unlock the razor and the shaver should work fine again.
This is a Braun design feature there to help prevent the shaver from accidently getting turned on when packed in your luggage, etc. and running down a fully charged shaver.
There is nothing like reaching for what you thought was a charged and ready to use shaver and discovering that it got switched on and ran the batteries down.
Other than having the lock off feature engaged, I can't think of anything that would cause the switch not to turn on, unless the shaver was dropped and damaged. If that's the case, you will want to have it looked at to make sure the printed circuit board hasn't been broken, etc.
Typically this isn't something that most folks can undertake a diagnois and repair, so I'd suggest you contact or call them at 1-888-476-1785 to get an estimate for repairing it.
Hope you find this Very Helpful and best regards!
Oct 06, 2009 | Braun Flex Integral 6520 Electric Shaver
Margaritaville Frozen Concoction - Ice shaver has stopped turning
On my machine (DM1000) there is a kill switch on the top & back of the ice reservoir. If that gets broken/misaligned the shaver will not activate.
Jul 22, 2008 | Margaritaville Frozen Concoction (DM1000)...
Norelco shaver won't turn off
You should check the switch behind the batteries. You likely dislodged the piece of plastic that presses on the switch. It's simple to place back properly--if that's what the problem is.
Jul 16, 2008 | Norelco Advantage 6705 X Electric Shaver
I have the same problem with my Braun 7570 as the Jan.8, 2008 writer about the 7526 or 7680 shaver. The blue button came off but the shaver still works
This button wears out or just fails with time, but is replaceable.
Braun 7526 Syncro Body Housing with Trimmer
$12.99, Fits Model: 7526, Type: 5493, Includes back case, front case with trimmer/switch, side grips and bottom 'plug',
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
Jul 07, 2008 | Braun Syncro 7526 Electric Shaver
Braun shaver 7505.
Need to replace the switch. If you have the skills to disassemble the unit, proceed. Otherwise replacing the shaver will cost you less than having it repaired.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 01, 2008 | Health & Beauty
Braun Shaver 360 Complete #8985
the 110 plugin goes into a circuit which changes AC to DC for charging the internal NiCad batteries. If there is NO charge whatsoever in the batteries, the shaver will not work. If you have any electronics background a simple test with a VOM will determine if the bridge rectifier is putting out any DC.[you must disassemble the shaver] If you have no experience on circuits take it to a repair location.
Sep 10, 2007 | Braun 360° Complete 8985 Electric Shaver
Wet/dry Panasonic shaver stopped
My model is almost the same as your model ...
Problem: Model ES7037CMB - Over the past month the Panasonic shaver would turn on with 3-4 tries, but now will not turn on at all – the on-off switch must be bad after only 7 months of wet use. Before sending in I found this diagram:
Disassembly: Remove bottom Phillips screw & end cap, pop off each plastic side with fingernails (reinstall them from top 1st), remove 4 screws, remove 2 clips, take top off. Remove battery case and the on-off little, white plastic lever fell out. Slide off the white plastic/metal on-off slider & clean contacts with knife … my bottom contact was black & top was clean.
Assembly: Reinstall on-off slider (white plastic with metal contacts) by sliding back in grooves -- hardest part - place the on-off plastic lever on the battery back unit – I tried to put it on the case and could not get it to stay on. Slide the battery pack back in with the plug prongs in the holes in the end being careful not to drop the on-off lever. Test shaver. Stuff battery wires inside case – screw 4 screws and add 2 clips on, then final screw in the end after cap placed on. Easy once I knew how to put the on-off lever on the battery side – that was tricky. Total time was about 1 hour – next time it will be about 15 minutes. Works great! jgg 12-27-08. Think I will use it dry from now own since it had a lot of whiskers inside of it and maybe wash only the head as needed with baby shampoo.
May 30, 2007 | Panasonic ES 8077S Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
228 people viewed this question
Top Braun Health & Beauty Experts
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
