Question about Home Theater Systems
Temporary Sound Interruption with my JSI Model JS 5010 Home theatre
Every time there is a loud explosion or something similar the sound briefly cuts out.  I have tried adjusting the DRC control tp on and off on this system but it has proven to be pointless.  I would appreciate any assistance regarding this matter.
SOURCE: Problem With Sound
THE SOLUTION KINDLY POSTED BY MARK TO A PREVIOUS PROBLEM SHOULD FIX THE SOUND ON THIS ONE AS IT WOULD APPEAR THAT THERE ARE INHERENT PROBLEMS WITH THIS MODEL AND THE SOUND OUTPUT Problem:posted by johnny 5 on Sep 02, 2006Report abuse Have had this sys for about 2 years and recently moved it to another room but when re-installed it would only play through the headphones. Moved it back to its original position but it hasn't corrected the problem. Best Solutionposted on Nov 19, 2006 By Mark140872 Rank: Not rated Rating: 0%, 0 votes Hi I've just fixed this problem on my DAV S400. It's down to dry joints on the Amp PCB. Very simple to fix if you know how to works a screwdriver and soldering iron! Take the cover off and with the back of the unit facing you, you'll see teh amp PCB in the left hand corner to the back. At this time its the wrong way up to fix it so you'll have to remove the Ariel connection box and the speaker connection PCB both are very easy to do. Lay these out of harms way but do not disconnect any of their ribbon cables as its not needed. Now you can unscrew the amp PCB which is bellow both boards you have just removed. Disconnect the phono wire from the PCB (keep a note of that) and disconnect the power lead to the PCB on the right. Up turn the PCB and remove the copper heat sheild. You should now find the dry joints. The phono plug you just disconnected fits into a multi socket on the PCB. This will probably be loose or have more than one dry joint. Re-solder all these making sure not to link any together. Now find the large brown capacitor and check these joints and if needed re-solder. Check for any other dry joints while at this stage if any look slightly poor give them a quick dab with the soldering iron but make sure you don't fry a chip!!. Re-assembele remebering to reconnect the phono wire. I allways check before putting the case back on. This worked for my S400 after my 18 month old got hold of it. Good luck! Thank you for rating this solution.
Posted on Jan 25, 2007
SOURCE: LG home theatre system model LH-T1000
Hi I have the same tv. How is the video signal coming out of the dvd player and what is it plugged into on the tv. I travel for a living and coach my wife over the phone all the time.
Posted on Sep 17, 2007
SOURCE: Unlock LG home theatre model LH-SW5100
at "no disc", press "pause" and enter "314159". when it shows CODE__, enter "0" for all code, press "pause" and the power button.
Posted on May 19, 2008
  • 8596 Answers
The SC-HT500 is only for use in the UK, Ireland, Australia, and a few other places - you will need at least a transformer if you want to try to use it in the US. The manual can be found here:
-Tha Mp3 Doctor
Posted on Feb 21, 2009
SOURCE: Onkyo HT R550 sound going in and out
Sh$T I had the same problem with an older model... went out and bought a new Onkyo... HT-R550 I have had it for 2 years as of January 2010
Posted on Nov 28, 2009
  • 395 Answers
SOURCE: need manual and instruction for panasonic home theatre SA-PT560
Posted on Jun 03, 2010
0 characters
1 Points
Lost instructions for my dav-hdx285 dvd home theatre sounds great when the dvd is used but when using sound from the tv sound is not nearly as loud and if i have the volume on the tv up it sounds like a...
Register and download the manual for free at
The TV and process the sound differently so the echo is a just a time smear. You shouldn't actually need to augment the HTS speakers with (ugh) TV speakers.
As far as comparative TV-sound loudness goes, if you drew it from the Cable Box to the audio system I'm sure it would be the same as your other audio. TV
Feb 21, 2011 | Sony Bravia DAVHDX285 Theater System
OK, it is called Cold Reset
Turn unit ON and press following 3 button on same time..
Display will show Cold Reset briefly and DAV-HDZ278 is reset to default settings.
Aug 20, 2009 | Sony Home Theater Systems
Is my tv audio doomed or will the home theatre system work anyways.
some devices these days have a built in volume control, try using your remote for which ever dvd player or satalite bix you use, on push the volume up button on it while you have the volume on the tv maxed out so that you will be able to tell a defference if it works or not.
Jun 02, 2009 | Philips HTS 6600/12 Home Theatre...
"Push Power'' and ''Protector"
my sony bravia is KLV-32S400A. i tried to stop the dvd playing and turn off the home theatre, but the tv is still on. suddenly there was a loud blast sound and the home theatre shows PUSH POWER PROTECTOR.
please help what should i do with it?
May 13, 2009 | Sony DAV-HDX500 System
JSI MODEL # JS5010 sound cuts in and out when using .
Make sure it's not overheating. I have this model and know that it just has a heatsink and no fan for cooling. Make sure nothing is on top of the unit, especially blocking the vent on the right...that's the cooling vent.
Also, check your cable connections to make sure they are all connected properly.
Feb 27, 2009 | Progressive Computer JSI 6 spkr. Home...
JSI dvd player, remote code
I have similar problem, solve it with codes from Koss brand.
Jsi and Koss are made by same lab.
Try Koss codes, it work for me.
good luck!!
Dec 29, 2008 | Progressive Computer JSI 6 spkr. Home...
Panasonic SC-PT850w sound cuts out
Are you watching 10HD off the air from an antenna? You are losing video and audio intermittently, which may just be indicative of a weak signal. Does your TV have a signal meter?
Apr 27, 2008 | Panasonic Home Theater System System
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Home Theater Systems
Dec 06, 2007 | Home Theater Systems
Home Theater Systems Logo
95 people viewed this question
Top Home Theater Systems Experts
Gyula Lacz
Are you a Home Theater System Expert? Answer questions, earn points and help others
