Question about Sony KP-51HW40 51" Rear Projection Television
TV not working
Tv came on tonight when I turned on the power. Picture only covered 3/4 of the screen, from top to bottom. Sound was great. The tv turned itself off after a few minutes, the trouble light kept blinking "7" times. I downloaded the repair manual, so I will look the codes for you tomorrow, if that works for you. Bill
  • 39 Answers
Re: TV not working
Vertical amplifier s faulty.Replace and resolder surrounding area.
Posted on Dec 14, 2007
0 characters
3 Points
Picture is bending at the top and bottom and looks 3d
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
Dec 15, 2008 | Samsung PCN5425R 54" Rear Projection...
Trouble with picture
Can you post a picture of your screen it sounds like convergence ICs. Also need your model number and does the picture look 3D
Jun 19, 2008 | Projection Televisions
Sony kp-53HS10 blinks 5 times then picture goes off, sound ok.
Pull off the front speaker grill after removing 2 screws on the bottom corners. The grill will come out from the bottom before it can come down, then it is off. Undo the wires ties by hand to get 1 foot slack in the cables. Remove the 4 screws on the 1' by 2' hardboard cover to get into the bottom of the TV. Find the 6 adjustment pots (2 rows of 3 pots) One row is the "focus", do not touch these. The other row sais "screens". These you need to adjust. Turn on the tv. Use the tv/video button to switch to a black screen. You need to go up and down to get "cut off" to black for each gun/crt. Turn each screen controal clockwise untill you see color, then counterclockwise slowly and stop when that color goes black. Do this for all 3 screens = all 3 guns/crts =red, green, blue. If this Sony adjustment does not fix it, than you may need a new gun/crt which is expencive.
Mar 23, 2008 | Sony KP-51HW40 51" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
No picture
need chassis # ctc something look for it on the back cover
Jun 19, 2007 | RCA P60921 60" Rear Projection Television
How do I Remove Front Cover Screen of Hitachi 53SBX59B53 Projection TV???
Did you ever find the solution to removing the front screen? I have the same problem. Please write at
May 05, 2007 | Hitachi 53SBX59B 53" Rear Projection...
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Light blinks 8 times
Best Solution by Guest worked!!! Great job and Thank you!
Nov 14, 2006 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
46 people viewed this question
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
