Adding a converter box was in the setup process and the screen now has rolling horizontal lines, help!
SOURCE: Jumping horizontal lines when connected to CD player
Hello, I want you to do a test first. Take you TV and connect a DVD player to it and see if this problem occurs. I bet you it wont, because the problem is not with the TV nor the CD of the karaoke machine. The problem is with the sync pulses of the signal from the karaoky, and the inability of the Tv to sync-up with those signals. What I would use is a video stabilizer between the TV and the DVD player. If the TV still has the problem with the DVD player I would then check the TV for a vertical section problem. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
SOURCE: the horizontal on the screen has moved i have a 2
i have same problem it happens with my hdmi and component port.
did you ever find out what the problem was?
