Question about Dell E173FP 17" Flat Panel LCD Monitor
46" Hitachi Ultravision
I have vertical white lines on my television screen. If you have any suggestions I would greatly appreciate it. TThis T.V. is about fifteen years old.                                          thanks
                                                        Todd Brown
  • Dell Master
  • 2,045 Answers
Throw it out?
Posted on Mar 27, 2017
Blue vertical line appearing / flashing on Hitachi ultravision plasma tv model number 42HDS52A ??
So the lines goes up and down or is it across from side to side, if it's side to side then it's your terminal power board.
Jan 04, 2011 | Hitachi 42HDS69 42 in. Plasma Television
I have an older model Hitachi 32" ultravision CRT tv. the video just collapsed into a thin horizontal line (about 1/4"). Video is fine. Any help would be greatly appreciated. Thanks.
TURN IT OFF AND DO NOT TRY TO USE---if a thin line left to right in middle of screen it is vertical problem---the set should shut down but even seconds count here--this can burn a mark on all three picture tubes instantly and it is permanent.
Problem if small line left to right in vertical circuit.
Let me know what you know and I will try to help--I know these sets very well.
Sep 22, 2010 | Hitachi 61SWX10B 61" Rear Projection...
Ultravision Digital TV has shadows and vertical
I believe it is either interference or a convergence issue. To fix an issue with convergence try to find a convergence setting in the menu. If thatr doesn't work try to clean your projection lenses with a q-tip and alcohol.
Good Luck.
Mar 14, 2010 | Televison & Video
I have a Hitachi Ultravision 61SBX59B TV. I have white vertical lines that move across the screen from left to right. What is wrong with it, and how do I fix it?
that white line is a high voltage leak have you had this set serviced lately? one of the hv lines from the flyback transformer
is not seated or leaking you need a tech to find it not a safety issue just an anoyance
Nov 19, 2009 | Hitachi 61SBX59B 61" Rear Projection...
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Sep 16, 2009 | Hitachi 36UX01S 36" TV
Horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Aug 30, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Black display with a horizontal white line in the middle.
Middle going across the screen from left to right??
This unit is plagued with bad solder connections in the comb filter board and flatpack underneath the comb filter board. These connections can cause any odd number of problems in video display. If it is that it's not expensive - virtually no parts. If it's a single line across the screen could also be the vertical circuit involved.
My suggestion is to have it estimated at a reputable shop and take it to them rather than the more expensive pu/del charges.
If you would like go to and locate a servicer from there. Kinda like going to the AMA to find a doctor...
Hope this helps!
Apr 18, 2008 | Hitachi 32UDX10S 32" TV
No picture or just one line across screen on hitachi ultravision rearproj.
Could be a loose connection on the printed circuit board in the Vertical deflection circuit.
You would have to have a qualified technician to repair this problem.
A intermittent connection in the circuit described can cause a horizonal line across the screen.
You have to be careful and not leave the TV on for a period of time with a bright line, as it can actually burn a line on the CRT screens, which is permanent.
Mar 24, 2008 | Televison & Video
Hitachi 50in. Ultravision Model #50ux14b
Vertical output chip has some ring cracks on leads (cold solder joints). Set is shutting brightness off to protect5 it's crts from burning a black streak across them.
Sep 03, 2007 | Televison & Video
Computers & Internet Logo
100 people viewed this question
Alun Cox
