I just installed this hardware onto my computer. I can't tell if it can read a CD because it keeps opening as soon as the door is closed. The door will not stay closed even if there is nothing in the drive.
Comments:
Oct 31, 2007
- Thank you very much!
Actually, it started functioning (miraculously) on its own, so I won't have to go through this procedure. However, this advice will come in handy if it happens again.
thanks,
PabloPablo
sounds like the drive lock is not seating properly, (gearing mismatch)
The drive tray lock is a peg on a round gear which locks into a groove on the underside of the tray (you can see it on the underside on the tray,
at some point this gear has "slipped" and now does not meet this groove and closes before hitting this groove, some manual manipulation of the drive tray can solve this but it is tricky
The easiest way is to "pop" the latch, which allows you to remove the drive tray completely This "latch" is usually a sprung toungue of plastic which normally prevents the removal of the tray, if this toungue is lifted the tray can continue on the gear train and can be completely removed, (the eject function will roll the gears forwards and backwards without the tray).
all you do then is to press eject (the mechanism gears will roll out) then you just insert the tray at the correct point (usually at full extend) to re-allign the tray lock (sometimes it takes a couple of attempts to get this right)
Hi my name is kerrie.. I am looking for a gz-mg26 burner. CU-VD10 SHARE STATION.Apacer AD330 DVD...
(More)
Hi my name is kerrie.. I am looking for a gz-mg26 burner. CU-VD10 SHARE STATION.Apacer AD330 DVD BURNER.I have looked ever where and can not fine one because it is a older camera they dont make them anymore. And the new ones do not work on the older one. So if there is anybody out there how would like to sell me one please help me out. thank you. kerrie.
Windows Vista recognizes the Memorex DVD- RW multi recorder w/Lightscribe device and the Lite-On...
(More)
Windows Vista recognizes the Memorex DVD- RW multi recorder w/Lightscribe device and the Lite-On CD-ROM device, yet fails to recognize the drivers sending an error code 10. It says the device is unable to start. How do I fix this problem?
The bonnet lift cable of my 96 holden combo is broken, any ideas on how to pop the bonnet or fix the...
(More)
The bonnet lift cable of my 96 holden combo is broken, any ideas on how to pop the bonnet or fix the cable?
