Question about Mitsubishi VS-45609 TV
Blue, red and green ghosting, curves in picture
My picture got a curve in top and bottom with red, green and blue ghosts. Adjusting convergence didnt do anything. Please email or call 212-960-3180
  • 1 more comment
  • ktop Dec 03, 2007
    Screen is curved at the top and bottom and the red, green, and blue are all shadowed in the text that displays at teh bottom of the screen.
  • Anonymous Sep 22, 2008
    Mitsubishi vs5076 tv picture norrow at top and bottom and color has ghosting.
  • CHUCKOG Sep 24, 2008
  • 4,402 Answers
Convergance amp ic bad
Posted on Jan 06, 2008
Akai (PTH5498) 54" rear projection TV with red and green ghosting and large curve in the picture at the top and bottom of the screen. Unable to fix using manual convergence. Thinking it must be the...
Yes is is your convergence IC's. One has gone bad, but consider replacing both of them because if one has gone bad then the other is not far behind. They are located on the middle board of your set. They are mounted on a large heatsink, the part # should be STK-392-040. Replace these and your set will work fine again.
Nov 15, 2009 | Akai PTH5498 54" Rear Projection...
Letters and numbers are 3d and curved picture
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
I have what I believe is a convergence problem. The red line curves down at the sides on the adjustment screen and when I am viewing TV the picture has a red ghost curving up at the sides of the picture....
Hi, this is a convergence chip failure and it can only be corrected by replacing the entire convergence board in this unit. This Board regulates and collaborates the RGB streams. if there is an apparent malfunction, it will become impossible to correct the issues you are experiencing at this time.
Simply replacing the convergence board or chip set will fix this issue.
May 16, 2009 | Zenith A50M91W 50" Rear Projection...
Green convergance wont adjust, bowed screen
Green really shouldn't be adjusted, you adjust red and blue to the green. When a color is bowed that indicates that a part or two are bad, probably the convergence output IC's and possibly a fuse or fusible resister. You may need a tech to come adjust it for you because after replacing IC's the adjustments should be done in the servicers menus not just in the consumers menus.
Mar 13, 2009 | RCA P52937 52" Rear Projection Television
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Mitsubishi VS-45609 TV Logo
262 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
