Question about Vivitar ViviCam 4100 Digital Camera
No sound when recording
I had my camera for only a couple months and the sound stopped working when I record video.  Any suggestions?
Sound you can NEVER hear when recording ... only in PLAYBACK on the PC
Posted on Dec 15, 2007
What is the function of video recorder for my car?
Like or just is the video camera, car video recorder is used to capture events, and important happenings.
Apr 18, 2012 | Video Cameras
Screen is black when in record mode but still record sound
Hi Keith: You can check menu settigns there? Take pics/videos and this appears black in the pc monitor after transference or download pics/videos? If your answer is yes, dont sound like a LCD problem.
The other choice, could be a malfunctioning CCD (Charge Coupled Device) image sensor... in both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check this link for additional details in this previous solutions for an Defective CCD and next contact your Samsung service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 14, 2011 | Canon MV700 Mini DV Digital Camcorder
My screen stays black, even though I can see old pictures, can record video (only the audio works) and upload my photos.
Could be a problem with the LCD screen viewer or CCD Image sensor go to bad. In both cases this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Olympus service. I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Good luck.
Oct 02, 2011 | Olympus FE-230 Digital Camera
How do I RECORD FROM A CAMCORDER TO THE DVD SIDE OF THE UNIT
  1. Connect the camcorders yellow, red, and white (Audio/ Video) to the input on the back of the combo called AV1 or Video 1.
  2. Then turn the channel on the DVD recorder to AV1 or Video 1. (A couple channels down from channel 2)
  3. Make sure camera is in VCR mode and hit play on camera
  4. You should see your camera video on your TV and rewind to the place you want to start recording and hit stop.
  5. Put an empty DVD in recorder and hit Rec. Button (usually red)
  6. Then hit play on your camcorder until you would like to stop
  7. Then hit stop on your DVD recorder and each section like this will be another chapter.
Good Luck
Oct 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Canon Powershot SD630 video only records a couple seconds
The card you are using is having a hard time keeping up with the video. Have you ever formatted this card before? Suggest trying a format of the card to see if that corrects the problem (NOTE this will also erase the card, so only do this AFTER you've downloaded all the photos/videos to your computer.
Press menu, select the tools menu, then select the item stating the card's capacity and select it. Then follow the on-screen prompts for a low-level format.
If formatting does not correct this, you might want to consider a better/faster card than what you're currently using. Be careful in purchasing though in that I doubt the newer SDHC cards will be compatible with your camera.
Jul 04, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Everything seems fine, but will not record.
buy a cleaning cassette and play three times and then try to record .
Feb 02, 2008 | JVC GR-D33US Mini DV Digital Camcorder
Pv-dv53d
1. Take out the tape - AND TURN THE CAMERA POWER ON
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on y ou should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS AND CREDIT TO LABBER
Oct 11, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Sound on my camera
Wooda,Go to the Fuji Website and Check if the Updated their software,I know a Couple of these Camera had Same related Problems Hope this Helps ttech
Jul 24, 2007 | Fuji FinePix A500 Digital Camera
Vivitar ViviCam 4100 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
