Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Kenmore 1067667461 light on but takes forever motor turn back on??
About once a week the refrigerator turns off and takes about more than full day till it turns back on??
  • 290 Answers
We don't see too many of these models anymore.
You either have a thermostat that is sticking or an icemaker timing problem.
The thermostat should be easy enough to check. When it is off for awhile you can try wiggling the thermostat knob and see if it comes back on. I am betting you have already tried this and it hasn't worked so that leaves the icemaker.
On this model of fridge you have the flextray icemaker. The defrost control and timer are built into the icemaker control. You most likely have some worn gears or pins in the timer mechanism causing it to stick in the defrost cycle.
You can still get replacement parts for it but I don't recommend trying to repair the icemaker yourself without some detailed instructions to go by because the mechanism must be timed to work properly. You can buy the complete rebuilt icemaker assembly and change it out. That is what I would recommend. You can change the whole thing cheaper than having someone come out and repair yours.
If you have a Whirlpool dealer around that has an older repairman that remembers how to work on one of these you could probably take the icemaker to them and get it repaired economicly. I would call them and ask before taking it up there because the fridge won't run without the icemaker hooked up.
Hope this helps
Post back and let me know how it comes out or if you have any questions.
Posted on Oct 30, 2007
  • Michael  Lindley
    Michael Lindley Nov 08, 2007
    Just wanted to follow up on your fridge problem and see what you found out.
  • Kenmore Master
  • 4,655 Answers
 Providing your model does not have a digital temperature circuit board, the defrost timer likely is bad. I tried to look your model up and had a problem because I think the make and model is listed incorrectly above your post..
The defrost timer should be near the interior light behind plastic. In the plastic is a plug or a small opening the size of a pencil in diameter. When it stops again turn the black screw about an 1/8 of turn clockwise. If the compressor comes back on the defrost timer will need replaced. If it does not help, try to find the exact model number listed somewhere on the fridge, most times behind and lower right hand corner with the door open, hope this helps, Thanks Sea Breeze
Kenmore Coldspot 106 Refrigerator
It's 12 years old it's gone ,they don't last forever ! Compressor !
Aug 18, 2015 | Refrigerators
New Kenmore - ice motor burned out ??
Taking a guess, ice maker fine. The wire bail is there to turn I'm on and off. Clear the ice from the fill tube with hair dryer.
Feb 21, 2013 | Refrigerators
Fridge was off for 5 months it was turned on and the same day and next day i put food in it been going one week and not freezing and not cool enough in the refrigerator
It probally has a leak in the sealed system. To do a quick check remove the back panel and check the frost pattern on the evaporator coil. It should have a light layer of frost over the whole thing. If it is only partialy covered it is low on freon. Fridges tend to leak faster when they are not running.
Jun 11, 2010 | Kenmore 64802 Top Freezer Refrigerator
Ice maker is spilling ice on the racks below
This is a common issue with all makes and models. Best solution is to turn off the IM when bin is full if yu are not heavy users of ice. I try to empty the bin and start fresh once a week if we have not been using it regularly
Dec 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Model 110 washer humming/popping breaker
Good day,
Anytime an appliance knocks a breaker down, the motor is the obvious culpret.
The first thing to do is remove the motor and take it to an appliance parts house for testing.
If the coupling broke, it is just sometimes just happenstance. In other cases it could be a transmission starting to lock up, which would overtax the motor, and eventually cause it to fail.
Lastley, most models are 2 or three speed. If the timer screws up and tries to run the motor on high and medium or low at the same time it will fry the motor.
Dec 10, 2009 | Kenmore Washing Machines
Refrigerator seem to not cool to the proper
your problem is in hte freezer area open the panel in your freezer you might need a new heat element or a new thermostat unit... not so bad to do or check...
arik from
Nov 06, 2009 | Kenmore 53092 / 53094 Side by Side...
Kenmore Refrigerator cooling fluctuating
IS this unit a frost free? I'm wondering if the motor in your timer is running slow.If that happens it could take too long before the freeze cycle comes back on. Or check the terminator out. Either that or check the electric to make sure nothing shuts off the unit like a timer for the lights.
Jun 10, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 106.7687461 about once a week refrig stop, light still on?
Try to locate the defrost timer. It sounds like the defrost timer has an intermittent fault and is not operating as it should. It should be situated in the compressor compartment. It is a white or black box with a little knob protruding from it. When the motor stops again, try turning the little knob on the timer untill you hear a loud click. The motor should then start running again. If it does, the timer is faulty. Replace it.
Oct 30, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore Elite Trio 795.7519
Either you have accidently left the door open at some time in the last few weeks or you have a faulty defrost sensor, initially turn off defrost freezer over night with doors open, turn on following day, unit should start to work within 12 to 24hrs, other wise replace defrost sensor but still deforst. Regards Advisor
Aug 26, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
82 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
