Question about Lenoxx Electronics CDR-190 Clock Radio
Need help the cd player doesn't spin @ all. when I turn the cd player on the laser moves but the cd does not spin.
  • Anonymous Nov 29, 2007
    CD spins, then cuts off and will not play.
  • 4,102 Answers
Their is nothing you can do yourself to repair this as it needs a new laser unit but the only thing you can do is take it to tv repair shop and they will fit a new one and get it recalibrated for sorry i couldnt offer you any more help................................
Posted on Oct 30, 2007
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
Apr 16, 2012 | Sony 5-Disc CD Changer with SA-CD Playback
CD Player does not turn
how long have you been using this player and when did this begin?
Remove the disc and try another. If the player refuses to eject the disc, remove it from the wall and fix it back and fix it back again. Then turn the player on.
If the player still gets stuck on "loading" mode for other disc, then it means the laser is weak.
The lens is weak such that it cannot load data on discs. Its spinning, trying to load, but can't because of the weak laser.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all discs again.
Regards.
Jan 10, 2012 | Panasonic RX-D15 Cassette/CD Boombox
I put CD into cd tray, the tray and CD go into the player, it says loading, but nothing happens and it continues to say loading. I cannot even eject the CD, I have to power it off and back on to get the...
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Once this us done, your player will play all DVD discs again.
Good luck.....
Sep 14, 2011 | Philips MX6050D System
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
Cd player doesn't work
This is doc-fix. The C D motor is supposed to spin spin, at all times when selection. then the C D record makes selection.
in that sequence.
See if motor spins by finger twirl? Is it turn 3,or 4 turns?
if it is binding on the black plastic, then that has to be corrected. if the motor is getting no power (electric power)
then there will be no spinning. need a diagram , showing how
motor power goes into the C D HEAD TO MEASURE VOLTAGE???
IN-HOME JUKEBOX REPAIR 6362273300
Apr 27, 2009 | Audio Players & Recorders
My dvd player dvp615 doesn´t play dvd discs. only music cd´s
The unit has two lasers one for the cd and one for the dvd, the one for the dvd is bad and the whole laser assembly needs replaced. Cheaper to buy a new player.... sorry
Mar 16, 2009 | Zenith DVP615 Portable DVD Player
Pioneer PD-F505 Cd Player - The player picks up the CD and it starts spinning. A high pitch squeel sound starts as soon as the CD starts to spin. The unit spins the CD for about two to three seconds and...
Sound like laser assy defected in any case you need a Technician from Pioneer or they are trained by Pioneer is very complicated to remove the laser and replace it you need an osilloscope to aligment a new laser and special disc to do that. It might not worth to repair it, the laser itself a bout $110.00 Aus
Nov 30, 2008 | Pioneer Audio Players & Recorders
Sony CD player C305 not playing
The laser or spin motor could be faulty.
Take it to a service centre for professional help.
John
Dec 15, 2007 | Sony CDP-CE375 5-Disc CD Changer
B&o sound system not working
try buying an ordinary cd lense cleaning (CD), if you are brave you can try adjustind the pick up of the laser on the laser board pot inside the cd player. it might just need a service
Nov 27, 2007 | Bang and Olufsen Beosound 2000 Shelf...
Lenoxx Electronics CDR-190 Clock Radio Logo
234 people viewed this question
Top Lenoxx Electronics Audio Players & Recorders Experts
Tony Mitri
Are you a Lenoxx Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
