Question about Frigidaire GLRT212ID Top Freezer Refrigerator
Frigidaire GLRT214RAW4 Water Collecting On Shelves
Water is collecting on the shelves (In a few days).  Any clues as to why and how to correct?
  • crafted Nov 02, 2007
    I still have water collection on the shelves. I verified that the drain section doesn’t have standing water in it. The water collects on all shelves. How dose the humid air get removed from the fridge? Something appears to be a-muck in that area.
    Guru:
  • 462 Answers
Verify where it is coming from feel the roof ceiling of the fridge, the walls.
Or is it from the shelves themselves?
Are the door seals sealing properly? take a $1.00 bill and try to pull it out. Proper door seals will have enough friction to allow you to feel resistance when you pull on the paper. (A $50 or $100 Will pull out quicker and make a lot more change... ;))
Too Cold of temperature and too high of out side humidity are the combination that causes this unless the drain is stopped up in the freezer. Or no defrost where the refrigerator wall is in contact with the freezer and the freezer is not defrosting as it should.
The freezer section has the only cooling coil. It sounds like it is blocked with frost and thus wont let the air circulate from freezer to refrigerator.
There is a defrost timer, (or board), a defrost heater, and a defrost safety thermostat. Any One of these or a combination of 2 can be your problem. If you have a energy efficient model that has electronic controls then you will have a board. The procedures for checking the circuit on a board vary by manufacturer of the board used and manufacturer of the appliance.
The defrost heater always has resistance and is attached to the freezer coil.
The defrost thermostat is also attached to the heater electrically, unless it is an electronic sensor type. Sensor types have a range of resistance that needs to be known to check and varies slightly with the temperature of the sensor.
If I haven't lost you here you maybe equipped with the life experiences that will allow you to do most of these checks. If its over your understanding I recommend you contact a reliable technician.
If this helps you please rate me as high as you can and thank you for using fixya.
Posted on Apr 17, 2009
  • 38 Answers
You have a plugged drain in the freezer. unplug refer, remove back panel in freezer. There is a drain hole under evaporator. Remove ice with hair dryer or steamer. Pour hot water down drain hole until it runs down into pan on compressor.
Posted on Mar 08, 2009
  • jwalsh0206 Mar 08, 2009
    Remove back panel in freezer and clear drain hole.
  • Frigidaire Master
  • 4,655 Answers
It is most likely the defrost timer, the defrost elements or a leak in the door seal or a blocked drain tube leading down to a pan under the refrigerator.
Water should be removed every 8 hours with the defrost timer telling the defrost elements inside the back of freezer (and out of view) to get red hot like the parts inside a hair dryer. If temperature in freezer increased any today I would consider calling someone to either replace the timer or fix the elements. Now if the door gasket is buckled the warm air will enter condensate and also cause the same thing. If you notice a temperature increase in the freezer and fridge, it's time to act soon before the food begins to spoil, Hope this helps, Sea Breeze
Posted on Oct 30, 2007
  • John Tripp
    John Tripp Nov 02, 2007
    I apologize that I did not receive your comment until today. Think the website had some glitches recently.
    The defrost will remove the water down the drain tube about every 8 hours. If defrost drain is blocked the defrost water has nowhere to go but remain inside the refrigerator. Sometimes the drain tube is blocked a the entrance with a piece of ice and the tube will need a part installed to prevent this from happening. Click on link below to address this problem. Click line 6 and see if this helps. My e-mail address is seabreezehvac@yahoo.com if you need to get me sooner. I hope to resolve you problem soon, Sea Breeze
    link>>>>>>>>>>>>
    http://www.applianceaid.com/refrigerator...
  • John Tripp
TheRepairGur
  • 27 Answers
SOURCE: Frididaire side by side refrigerator- water freezing in bottom
Frozen or Plugged Defrost Drain
On Side By Side Refrigerator
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models the pan is accessible without removing the back panel and others are not.
Once you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster like this one: Turkey Baster http://www.repairclinic.com/SSPartDetail.aspx?PartID=428708&PPStack=1
To squirt hot water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
Posted on Jan 27, 2009
wheelshot
  • 102 Answers
SOURCE: Water draining under crisper bins & onto shelves. Try again
Your drain tube is stopped up. Take the panel off in the freezer section and chip away the ice in the pan below the coil. When you get to the drain hole pour hot water in it until it free flows. You will need a towel in the freezer to catch the excess water. Run some extra hot water through it to assure that you clean the drain out good.
Posted on Apr 01, 2009
Healeyman
  • 1198 Answers
SOURCE: water collecting on the shelves
Sure are a lot of sweaty fridges out there. My wife complains about it too. A mis-fitting door will allow moist air inside. Brute force usually fixes that. I just put my foot against the door bottom and bend the door back to where it belongs. If it has drooped, try just forcing it back up. And don't keep the door open too long when looking for stuff.
Posted on Apr 25, 2009
SOURCE: Water collecting in bottom of fridge
NO SOLUTION!!!!
a ?
how do i stop it?
Posted on Jun 16, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Water is collecting on the shelves in the main compartment
Sounds like a typical defrost drain blockage. Not sure what model of profile you have if older or newer stile but when the defrost cannot drain to the pan below the refrigerator the water collects inside th refrigerator creating a mess. I'm going to send you to another web page that will help you see a better idea of just what i'm saying so we can help you resolve the problem and learn how to clear the drain and get the water to stop messing up everything. Be right back putting our daughter to bed and brushing her teeth, Sea Breeze
Posted on Mar 02, 2010
Where is the defrost drain
Back behind the metal "wall" at the rear of the freezer, there is a raised "shelf" with the drain in it. Pull our freezer racks or shelves, remove a few screws, renove sheet metal "wall", and you will find it at the bottom there.
Jul 22, 2014 | Maytag Refrigerators
Where is the drain hole for this model
Good Afternoon Friend,
I understand that you are looking for the drain hole on your Frigidaire refrigerator, model# FFHT1725PS, due to water building up on the shelves inside your refrigerator. There technically is no drain in your refrigerator. There is a drip pan, which collects water from the condenser underneath your appliance. There are some possibilities that are causing the water to build up on the shelves. First, make sure that all containers are covered. Condensation can evaporate from opened containers and create water on the walls and shelves. Secondly, make sure that the drawers that have your fruits and vegetables are completely closed and set to the correct setting. Fruits and vegetables are full of water. Thirdly, check to make sure that your doors are closing and sealing correctly. Moisture can come through an open door or a door that is not sealed correctly. Lastly, if it is hot and humid, make sure that you are not going in your refrigerator many times and holding the door open as well. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire FFHT1725PS 16.5 cu. ft....
Mar 01, 2010 | Refrigerators
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
Water collecting on the shelves
Apr 11, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water of unknown source is on shelves of refrigerator
could it be from the ice maker or the water in the door.
Mar 24, 2009 | Kenmore Refrigerators
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Frigidaire GLRT212ID Top Freezer Refrigerator Logo
274 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
