Question about Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT
My Canon Rebel XT camera just started acting like there is a short in the flash, when i press the shutter button half way down, the flash goes off  2 times, and sounds like it is wiring that is shorting out. Not sure if it is a easy fix, or if it needs to be looked at.  thanks Melanie
  • doorhorse Dec 08, 2008
    I want to bump this up because I'm having the same problem. Camera will take a couple pictures with built in flash then it sounds like it is crackling and shorting out. I take very good care of my camera, it has not been dropped or anything and I surely don't have that many pictures on it despite it being 3+ years old...HELP if any before I have to send off to repair.
  • 20 Answers
It is normal. Camera lightens surrounding to get focus point.
Posted on Feb 13, 2008
Auto focus my canon d1000
Press the shutter button half-way and listen for the beep...then push the rest of the way to take the picture.
Mar 15, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Snapping problems
You may be experiencing "shutter lag". When you take a picture, you should press the shutter button half-way to allow the camera to lock in the focus (it will beep) before pressing the rest of the way.
Jan 21, 2010 | Canon Rebel XT / EOS 350D Digital Camera
How do i swap from eye view to screen for picture taking where is the button located to swap from one view to the other i dont have the manual cannon eos rebel xt
There is no such button. The Rebel XT operates as SLRs have operated for half a century: you compose through the viewfinder, the mirror flips up when you press the shutter button, etc.
You can download a manual from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=ModelFeaturesTabAct&fcategoryid=215&modelid=11209#DownloadDetailAct
Dec 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Auto focus problem
If you set the camera on "manual", it assumes you focused manually and allows you to press the shutter without having to stop half-way. Check your settings.
Oct 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Auto focus does not work in creative modes
That is a custom function of the camera that can be change back to default with ease. While in one of the creative zones press the menu button and navigate to the 5th and final tab on the top right. 8f5da8f.jpg
This is the Setup menu 2. In this menu, select “Custom Functions (C. Fn)” . This will open a submenu of numbered options. Select #04 and set it to 0: the default AF/AE lock on a half depress of the shutter. 7528356.jpg
That should get your camera back to the expected auto focus with the shutter button.
Mar 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Camera does not fire external flash
Is it in manual or auto modes (camera)Try resetting the camera back to factory defaults as a first step.
Feb 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rbl XT out of focus in viewfndr when shutter half way down
It's possible that the reason the "pictures turn out fairly good" is that your f-stop is set high enough that even though the image isn't properly focused, you have enough depth-of-field to bring your subject into "near focus". Does your lens try to focus back and forth when you half-press the shutter? If not, double check that the lens is in autofocus and not manual focus. You can also try cleaning the contacts between the lens and camera. Take the lens off, and then one-at-a-time clean the contacts on both the lens and the camera, using a clean pencil eraser. Gently rub the contacts. Be sure to hold the item upside down so that the eraser debris falls on to the table, not into the camera body or lens!
If none of this helps the autofocus may have become damaged and you need to have the lens and camera looked at by Canon Repair.
Jan 10, 2009 | Canon Digital Rebel XT / EOS 350D Digital...
Flash Problem
Hey tombston,
An error code of 99 is Canons general error code for this camera, and they suggest cleaning the lens contacts and/or removing the battery and then reinserting it. If this doesn’t work I would try resetting the camera to the default factory settings, and directions on how to do this are on page 35 of your camera manual. If this doesn't work I would have the camera looked at by an authorized service technician. I have included a link to a PDF download of the camera manual in case you need it. I hope this helps!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=215&modelid=11154#DownloadDetailAct
Sincerely,
Allan
Go Ahead. Use Us.
Jul 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Shutter speed on sports mode
don't get too far ahead of your self-leave camera on auto mode-put lens on a and hold button half down to let camera autofocus-learn how to use a continous mode to take multiple shots more important than playing with shutter speeds for now
May 29, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
82 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
