Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV35S66
Very odd. I lost my picture. It will turn on and has the green 3 on the right hand corner but that is it. I took off the dvd so I only have the cable wire going into the cable box and from the cable box to the tv. It was manufactured October 1999. It has been very reliable. Its to heavy for me to bring to a tv repair shop. Is it worth having a repair done in house? I paid $899 and it has the pip feature.  Should I make this as my excuse to buy an HD flay panel for my wall?
    Problem Solver:
  • 20 Answers
Dear EDKELL,
Before you buy that HD flat panel. Try this; disconnect the cable going in to your cable box and connect it directly to your set's cable RF connector at the back of the TV set, then try changing channels with the TV's remote, you may need to do an Auto Program first. Also make sure you select the correct tuner, that is tuner A, or B.
Hope that does it!
Toprol
Posted on Nov 08, 2007
Remove other picture
With the Sony Remote (brand indicated here) select the PIP button to turn that feature off.
Mar 28, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Color of green in upper right corner and lower left corner
Hello; You probably have a CRT type set. Something has magnetized your CRT/Picture tube. The set has a built in degaussing system that will only work when you turn on the set when it is COLD ONLY. If after several cycles of turning on the COLD set and the green color hasn't gone, the circuit in the set for doing this has failed, OR you have the set near strong magnets, such as speakers. PUT ALL speakers at least 4 feet from the set and go through these off on COLD cycles. The deflection yoke on the picture tube could have moved due to Sony using crappy adhesives to hold the yoke positioning wedges in place. I am so glad to be done with Sony!!!!! John
Feb 13, 2011 | Sony FD Trinitron KD-34XBR960 34" TV
My sony kv-36FV300 will not respond. won't turn off .....or turn stations. The picture is snow...and has a "7" in the upper right hand corner. ....and has "no signal" in lower left corner.
Just wondering if thesmiths860 found a solution to their issue w/ their Sony TV. My tv is doing the same thing i.e. snow, won't change channels and says "NO SIGNAL".
Does anyone have a solution? I don't have the original remote so I can't do a factory reset.
May 04, 2010 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Green numeral in upper right hand corner will not
There should be a button marked i,press this and it should disappear
Dec 08, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Bright green 3 in the upper right corner of my TV
press the display button on your remote.hope this could help you.u
Aug 19, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
37 inch sony xbr with tru surround tube tv
can you turn on the tv manually? or with the original sony remote control
are you using the channel 3 or any video input to display the tv picture.
thanks
Aug 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
91 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
