Car roll over no spark and some time it quits going down road then will restart in 10 min
SOURCE: 1999 Blazer 4wd - Trans jump's HARD to 2nd gear on takeoff
shifts off electric servo controlled by cars computer , see trans guy you can trust could need service ,oil and filter changed or part , like i said see one you can trust .
SOURCE: 2002 Monte Carlo wont start
sounds like your passlock sensor on the ignition barrel is faulty. you will have to go to the dealer to have it replaced because of the programming after replacement.
SOURCE: Heater blower doesn't work
it sounds like the themostat has stuck open. i would change the themostat and also make sure that there is no debri caught in the grill . make sure the plow is not blocking air flow
SOURCE: trans problem
OK this is a very common problem. there is a 4 pin connector on the trans. (just below the air box area sometimes blue or grey)(in a shape of a box) that is your TCC soleniod switch connector. just dissconnect that and see what happens. if your problem stops then you need a TCC solenoid. what that does is it locks up your converter at 40mph+ or HWY speeds to save on gas. another way to test it is when your slowing down and it feels like your driving a stick shift and it wont get out of gear and stalls. if that is what is happing thats your problem. just dissconnect it if you want but i remomend getting it fixed. DO NOT REBUILD TRANS. many trans shops try and pull a rebuild on this.
Michael
ASE certified
