Question about Sony KP-61HS30 TV
Problem my tv looks like 3d piture and it look like is the piture goes down
  • jennifer849 Oct 15, 2008
    We purchased our Sony Projection TV KP-61HS30 about 6 years ago - and we looveee it (STILL). Just the other night - for the first time, I am getting some massive issues with the screen. The Reds, Greens, and Blues are all separating and the image is bowing in the top & bottom. What can I do to fix this?
    Thanks!
  • Sony Master
  • 3,459 Answers
Bad chilps
Posted on Mar 27, 2012
  • Edward
    Edward Mar 27, 2012
    Or it was not done right, you can google for sites like tr repair kits to get a parts kit with instructions
Hi three months ago my kp-61hs30 tv looks like 3d picture and technician man replaced the two convergence Ic's but last night my tv looks like 3d picture and it look like is the picture goes down
i don't know why happened again
Posted on Apr 26, 2008
Menu pops on and off for about a minute when i first turn the tv on
the self diadnostic program in the tv is going bad.. may be time to replace the tv or dont shut it off completely
Jan 21, 2014 | Samsung LNT4665F 46inch 1080p LCD HDTV
The power on no piture
If the power light comes on (green) for a few seconds and goes off:
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Nov 06, 2012 | Mitsubishi WS-73713 73" Rear Projection...
Led of viera panasonic tc-46pgt24 flashed 7 times?
that means you are having a problem in the high voltage section of your tv and it goes into 33kv..check how your power supply is regulating and your horizontal circuit..your set goes into saftey shut down. if you are not a tech..then i advise you to have a tech look on your set.good luck.
Sep 13, 2011 | Panasonic Viera TC46PGT24 3D Plasma TV
My Sony kp57hw40 looks like it is in 3d after it has been on for awhile it goes back to normal
It starting to died.It will happen for good.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have pictures colors shadows or 3D picture look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The Shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Sony KP-57HW40 57" Rear Projection...
My Toshiba projection screen TV the picture is bowed and the colors don't line up
3d colors not lining up poblem dicates "convergence issues.. bowing piture may indicate complete faliure of convergence alignment cuircits... depending on model the most likely cause will be 2 micochips (ic's called stk<s)
Aug 23, 2010 | Toshiba Televison & Video
Piture looks like 3D
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Nov 15, 2009 | RCA HD52W59 HDTV Projection Television
Picture problem
3d pitures are a indication of convergence problem. is the picutre bowed in at top and bottom. DO you have the convergence option under the setup menu.
Nov 03, 2008 | RCA HD52W56 52" Rear Projection HDTV
Goodmans GTV30W2LCD Sound with no picture, screen flashes up at switch on then again goes blank.
mine has just done the same thing, i had someone look at it and he said the picture had gone. its not worth repairing it as it cost more than the tv is worth. your better off buying a new tv.sorry.
Apr 15, 2008 | Televison & Video
3D picture stlye Samsung SP55W3HFX
Hi Ross, This repair is quite easy, But before I tell you how to fix the problem I need to know have you gone in to the user menu & tried adjusting the convergence This will save time & expense for you ? If you havent then try this first it may sort it out without needing to dismantle the set. Let me know how you get on by either replying to this post or let me know via email dyson@gawab.com Chris..
Oct 06, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-61HS30 TV Logo
345 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
