Question about Pioneer DEH-P2000 CD Player
Pioneer deh-p2000 cd player
Someone installed this cd player in my 1992 GMC Sonoma, but they failed to hook up the wire that allows radio stations to stay in memory, or to start my cd at the spot it was stopped.  Now it restarts at the beginning each time.  I need to know what wire to hook up and what to hook it up to.  I can't find a manual for this model or a wiring diagram.  I really appreciate any help you can give me.  Or if you can't help, could you please point me in the right direction for some help.  I am so tired of writing down my cd book track and numbers and then having to fast torward to that point.  Please help me.
  • 626 Answers
Re: Pioneer deh-p2000 cd player
I checked the Pioneer Database and your device is no longer supported.
But I have installed several Pioneer products over the years and they a re pretty consistent in their wiring patterns.
There is a Yellow wire on the harness that is much larger diameter than the rest. This is the one that needs to be connected to a constant +12 volt source to alleviate your problems.
Best of Luck.
Posted on Oct 30, 2007
0 characters
3 Points
I have a Pioneer DEH-P2000. How do I program the channels?
On most of the Pioneers you can program the channels by tuning to the station you want, then pressing and holding the number key you want it stored to.
Hope this helps
Mar 01, 2011 | Pioneer DEH-P2000 CD Player
Setting radio stations, Pioneer DEH-P2000
you can seek to a station you like and then choose a preset button 1-6 . press the chosen preset button for a few seconds until the display blinks. the station should then be locked into that preset.
Jan 04, 2011 | Pioneer DEH-P2000 CD Player
Tring to install a pioneer deh-p2000 cd player in my 1994 volvo 850the speaker/power wiring is not the same
you must buy a wire harness connector from best buy or another dealer with knowlege and parts available / ps with this connector you just connect the wires from the radio to the connector following the color diagram and then snap on the connector to the car plug and it will work..
Jul 19, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
With the pioneer cd player,Can I wire the yellow
If to connect in your car, red is constant power (for memory of stations, etc.), and yellow is accessory in your car (when key is turned on to ACC, to power receiver). If receiver used for other application outside of a car, make sure you have enough separate fuse protection and place an ON/OFF switch in series with your yellow wire, to avoid power sorurce being drained.
Hope this helps
Jun 08, 2009 | Pioneer DEH-P2000 CD Player
Can not find a wireing diagram for a pioneer DEh-p2600
Pioneer follows the universal after-market color code, so if your CD player was made in the last ten years or so, the wires should go like this:
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
May 30, 2009 | Pioneer DEH-P2000 CD Player
How do I know if a new/used car cd player will fit?
yes.......... just buy a mounting kit for your car and a wire harness for your install just unplug factory radio and clip the harness on to factory plugs that you just unhooked from factory radio now just attach the same colour to colour wires from your new deck to the harness......mounting kit comes with instructions
(make sure to buy WIRE HARNESS & MOUNTING KIT for your car) and your install should take less than a hr to do
have fun
Feb 18, 2009 | Pioneer DEH-P2000 CD Player
Setting radio station to a channel on a Pioneer DEH-525R cd player
Scroll to the station then press and hold the preset button you want it to goto.
May 23, 2008 | Pioneer DEH-P2000 CD Player
Setting radio stations on pioneer DEH-525R CD player
Scroll to the station then press and hold the preset button.
The solution for setting the radio station on a Pioneer DEH P2000, is to tune the station you want programmed and hold down the desided channel number until the program number appears on the display.
Pioneer deh-p2000
Turn off the radio with the ign. on press and hold the aidio button
Nov 11, 2006 | Pioneer DEH-P2000 CD Player
Pioneer DEH-P2000 CD Player Logo
246 people viewed this question
Top Pioneer Car Audio Receivers Experts
xxxxxx xxx
Are you a Pioneer Car Audio Receiver Expert? Answer questions, earn points and help others
