Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
What do the direct drive do if it need a push to start spin onley at the end of cycle
    Problem Solver:
  • 8 Answers
Usually, an electric motor has a large capacitor connected in parallel and one of it's functions is to help start the motor spinning. try to check this capacitor and replace it with a new one if defective.
Posted on Mar 13, 2014
SOURCE:
The end of the lance won't spin
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Your next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washerhttp://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN
Apr 02, 2015 | Washing Machines
Why are Clothes are too wet at the end of cycle?
Mar 28, 2015 | Washing Machines
Lg front loader when during the cycle is the bleach dispenced
bleach? do u mean detergent? normally machines run pump/then start to fill.water will pass through drawer then they heat /wash/drain/spin then refil for rinse conditioner/spin rinse drain fast spin end pretty much
Aug 08, 2014 | LG WM2101HW Front Load Washer, White, 4.0...
At the end of the spin cycle there is a whirrring sound like two gears meshing together and winding down. this machine si 13 years old, top load, direct drive. There are no other noises during any other...
Possible problem within the GEAR BOX as this is a direct drive. So you will need to remove the drive box and check within if the lubrication is low , if the bearings are bad or the gears are worn out as the case when the spin ends on the higest RPM.
Proper resetting with lubrication must solve the issue.
Jul 14, 2011 | Maytag Washing Machines
LE error after full cycle toward end of wash it comes up with an error. not sure if it LE or upside down F E? Anyone have this prob?
LE toward the end of cycle probably means you had a bulky load which you tried to spin out at the high spin speed setting. Use a low spin speed with bulky loads. For this load now, just put power on and without selecting a cycle, push the spin speed selector button until a low speed comes up (should be about a 14 minute display) then push start to do a pump and spin only cycle.
Sep 25, 2010 | LG WM2277H Front Load Washer
End of wash cycle, no draining or spinning, but can move to rinse cycle and it agitates again, no spinning after rinse either
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The drain and spin functions are started when the timer advances to the spin mode.
The motor is reversible. When agitating, the motor spins one way, when going to the drain / spin mode it reverses.
Since the machine agitates, the problem points to the timer.
Sep 04, 2009 | Kenmore Washing Machines
My all in one washer dryer by kenmore is direct drive. the spin rinse spin functions work on all three cycles ie. delicate, permanent press and regular. the fill and agitate functions at the beginning of...
can you get it to start by moving the timer one more click past the beginning of the cycle? Sometimes that is all that is wrong. Other than that, it's more than likely the timer has fused some of the points together and you will need a new timer in that case
Aug 24, 2009 | Kenmore Washing Machines
Need to initiate cleaning cycle
to enter the cleaning cycle:
Select the RINSE & SPIN button.
Select Low SPIN SPEED'
Select Warm/Cold WATER TEMPERATURE.
Select the 2ND RINSE Option.
Push the END of CYCLE SIGNAL button 4 times within 5 seconds to start cycle
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
My washing is still very wet at the end of a wash cycle and when I try to put the washer on a short spin cycle nothing happens. the drum is definitely turning through the wash cycle but not turning very...
Could be an issue with the timer. For the typical later model Whirlpool/Kenmore direct drive washer the motor always turns in the same direction while agitage and spin go in opposite directions. There is a transmission/gear box which allows whis to work. The timer is supposed to pause for about 10 seconds just before the spin cycle to allow the motor to stop and then start again when the gears are set to spin mode. A bad timer (which is a common problem) may not be allowing this reset and the washer won't spin all of the time although it may agitate and may spin some of the time.
Tell-tale sign of a bad timer is a small burn mark near one of the connectors. You may have to remove the timer to see this and even then look very closely.
A new replacement Whirlpool timer will run you between $100-150 for the part.
Hope this helps.
bd.
Sep 16, 2008 | Whirlpool Washing Machines
Loud noise, then not so loud, but now electrical burning smell and little draining
The basket drive and the drive block will need replacing. The nut that holds the basket to the drive block may have come loose causing the drive block to 'jump' over and damage the tabs on the basket drive that causes the thumping as the spin cycle ends. To repair, you will need to purchase a basket drive and drive block. The agitator, balance ring, basket and transmission, will have to be removed in order to replace the basket drive. If less than 3ys old, consider contacting whirlpool for possible warranty concession.
May 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
20 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
