Lock out on a goodman furnace
I have A goodman furnace MOD # GMS80903BNA . that the HSI will come on for a little bet , then shuts right off . The L E D is saying that I have A lockout. what should I do
  • Anonymous Dec 04, 2007
    furnace goes off on lockout smell of gas
  • 1,420 Answers
I have attached a link to download your owners manual troubleshooting guide. There is suggestions to follow coorisponding with the error codes.
http://www.dnmech.com/lit/IO-242.pdf
Posted on Nov 02, 2007
Hi, I have a Goodman GMS80903BNA Furnace and recently what happens is that when the thermostat calls for heat the draft inducer motor starts. However, after this nothing seems to happen. I don't h
Youcould be loking at the pressure switch try jumping it out and see if it lights some times you can fool it in to working , check the hoses are tight and nor spilt or take a drill bit and just clean out the 2 ports where the hoses fit some times they get blocked , also check you air filter is clean and your fan
Dec 18, 2012 | Goodman GMS80903BNA Heater
1993 goodman status light 4 times blinking
Witch blower is running, the inducer or the systems blower?
System blower could mean the the high limit is opening and shutting down the systems gas train, I would check this out first.
The other problem could be with the pressure switch for the gas train, it is supplied from the inducer motor, check to see if it is operating fully.
HSI boards do go from time to time, this sounds more like a system control problem.
Jan 24, 2008 | Goodman GMS90703BXA Heater
Power had been out and wont kick on we have power now
did you remove your furnace doors? they need to be in place for the furnace to work.make sure they are in place correctly
Feb 02, 2011 | Goodman GMS80903BNA Heater
Goodman GMP075-3 not igniting. Everything cycles as it should but HSI does not glow. Thermostat is set to heat, temp approximately 10 to 15 degrees higher than room temp, blower motor starts, relay clicks...
The flash code is due to the furnace not proving flame 3 times in a row. If you have a multimeter you can ohm the ignitor out to see if it is good. Depending on the type (silicon Nitride or silicon Carbide) you can verify if it is good. A silicon Nitride ignitor looks like a small thin straight bar type will ohm @ 11 - 18 ohms, a carbide ignitor looks kinda like a tuning fork (sorta) will typically ohm @ 40 - 92 ohms. anything outside of those ranges will require a replacement.
Nov 02, 2010 | Goodman GMS90703BXA Heater
Gooman heater connected to electronic lux 500 thermostat. no response from heater at all. tried changing batteries in thermostat.could thermostat possibly be bad. had both for approx.11 years
Remove t-stat and remove red and white wires and connect them, if unit starts then it was the t-stat.
If not go to furnace and remove same two wires at furnace and jump out at circuit board or connect wires FROM furnace, if it starts the problem is in wires.
If you have power to furnace?? and nothing happens it is either a bad board or inducer motor (little one) is not starting. Remember that their is a fuse on corcuit boards that need to be checked.
Feb 04, 2010 | Goodman GMS80903BNA Heater
Bad control board?
This is a good one! I would check for a blocked vent or intake pipe first. Also check to make sure the condensate lines are free of moisture or debris. What is the code for three blinks?
Oct 11, 2009 | Goodman GMS807034ANA Heater
Goodman gmn100-4
Put water in the condensate trap
May 28, 2009 | Goodman GMS80903BNA Heater
Goodman GMP075-3 heater blinks continuously,
Most all of them furnaces trouble shooting sheets located with the wiring diagram . Count the number of time it blinks and look at it on the guide it will tell you whats wrong
Dec 05, 2008 | Goodman GMS80903BNA Heater
Heating & Cooling Logo
912 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
