Question about Linksys Wireless-G Broadband Router
My laptop cant find the connection
After I restored my gateway laptop.  I cannot go on wirless anymore.  But the other laptop I have works out fine.  WHat can I do?
  • 30 Answers
Re: my laptop cant find the connection
Do you have an wireless icon?
Are you able to view the available wireless networks? If you are, then highlight it (left click once), and click "connect".
If your router is public, without a key or password, if all things are set correctly, you should be connected.
If you still cannot connect, compare your wireless settings to another computer that is connected to the network.
If you still have configurations issues, seek more knowledgeable help locally.
Hope this helps!
Posted on Nov 10, 2007
  • 193 Answers
Reboot the laptop make sure the w/l connection is enables>and right click on teh w/l i-con u can see on teh left side bottom corner on the laptop and select view avaliable networks(SSID) click on ur network and connect>and click on prefered net works and click on the network (SSID)>AND CLICK ON CONNECT RATE ME SOLVED IF ITS HELP FULL THX
Posted on Oct 30, 2007
0 characters
3 Points
My computer is showing the conection but not letting me on the internet how can i fix it?it says conneted and says no internet access.
1) try turning off and restarting the modem and router.
2) if you are using a dsl connection check if the modem is in bridge mode with your isp.
if yes then
type click on start->run->cmd and press enter
in the black window type ipconfig
now note the default gateway and type the default gateway in the internet explorer Eg \\
check if the router is set to connection type as pppoe.
enter your usernaem and password and save the internet light will go on.
if the modem is not in bridge mode then try connecting you pc directly with the modem and check if the internet is working not not. if not contact your isp for settings.
if internet is working fine.
not connect your router to your modem and then your router to your computer.
check if the router is set to optain ip automatiicaly and save changes.
if you still face any issue let me know.
Jul 05, 2010 | Linksys Wireless-G Broadband Router
I cant go into the router i think i changed something on the router setup and now it cant go back in.i can connect to the internet directly from the cable modem but when i plug it in the wirless router it...
Try using the hardware reset button on the Linksys. Every settings / changes you have done will reset.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
direct FixYa link:
Jul 07, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I have a Westell 327w My companies laptop connects fine but my daughters laptop will not. Her computer can connect to other wireless just not ours. Any help greatly appreciated
may your wirless is prodected by password
just folow the setp
click on wirless icon on screen try to connect it will ask you password
if you don't know the pass then
in explorer type your IP e.c.
then it will ask router password just apply then you will able to see your wireless password from the router setting
May 30, 2010 | Westell Wirespeed VersaLink...
My laptop wont connect to my wireless router, but my desktop which is directly connect will?
You wirless switch has to be turned on for that to work. If that is not the issue then sometimes it it best to plug it in to the router and set it up that way. the computer already recognizes the computer and it finds it easier to set up the wirless.
If you want to make it real easy to manage your computers and the internet. Download a network manage ment program. I will help you connect you computers to the internet and much more. Network Magic Pro or Network Magic Essentials $30-$50.
I hope i have given you information that has helped you.
Thank you for the chance to help as well...
FixYa Support Expert
Nov 05, 2009 | Linksys WRT160N Wireless Router
Wirless networking
The red line through the icon indicates that that network adapter is disabled in the device manager. (You can enable it by right clicking My computer, choose Manage>device manager. But the realtek is used for your ethernet cable connection. The 1394 connections are network adapters used for network connections to printers, etc. probably left over from your work setting, and can be disabled for the moment.
You don't mention what OS you're using, but I'll guess XP, and provide another link for vista just in case....
In any event, it's going to be necessary for you to reconfigure your network connection to the router/gateway you're using at home to connect to your ISP. Here's a general wireless networking troubleshooter, in the event that you've already covered the basics. And here and here are articles/links that will give you more advanced guidance. (Also here.)
But here and here are links to basics: to help you set up and maintain a network in xp, and here's an alternative for vista.
Another excellent resource to help you answer questions and troubleshoot the connection is this site, which has specifics that deal with many common ISPs.
In the end, you may find the easiest thing to do is start at the beginning by setting up a new home network and working through each step to establish a new connection.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 23, 2009 | Routers
Wirless network - laptop
See what ip,gateway and DNS its getting from the access point.If its getting the right ips then your network should work. If it is not getting the right ips then there must be some problem in the DHCP configuration of the access point
Jun 25, 2009 | NetGear WGT624 Wireless Router
Wirless problem
- Kindly try to restore the web browser settings on your wireless computer.
Mar 12, 2009 | Linksys WRT160N Wireless Router
Wanting to connect 2nd computer to internet, have router
If it is by wirless you will need to adjust the wirless adapter setings by going to your network conecsions click on the wirless conecsion and confiqir it to use stronger setings it should have a descripsion for all stings. I hope this will help you. Also do not forget to vote.
Jan 17, 2009 | Gateway Cable/DSL Router - 4Port [ Belkin...
Wirless router
The last thing you want to do is get rid of the password - operating an unsecured WiFi network can be very hazardous to your privacy & finances! You need to set the WEP password in the PC's. If you install the 3Com router software and use that to set things up, it will guide you through doing the job.
Also, it's better to use WPA encryption rather than WEP which is now regarded as insecure and little better than nothing at all. If you can get it working OK on WEP, it'd be easy enough to change it to WPA in the router & then change the setup on the PC's.
Unless you live in the back of beyond, this really is necessary I'm afraid :{
Jul 15, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Linksys Wireless-G Broadband Router Logo
Top Linksys Routers Experts
 C. Dante
C. Dante
Are you a Linksys Router Expert? Answer questions, earn points and help others
