My plumbing was clogged- we have fixed that - however now the dishwasher - motor runs while the door is open- and the water does not come out at all??? Seems stuck and nothing else happens
Not sure what is happening-HELP!!! The dishwasher is fairly new
thanks
Dana
depending on the brand and mdl the unit may be equipped with an overflow safety. If ther is water under the dishwasher in the floor pan then the sensors will trick the dishwasher into thinking it is leaking. Check under the kick plate . if it is moist then take a hair dryer and dry it up up until there is no moisture at all. This should cancel out the pump command and you can start over .
The dishwasher runs but the top sprayer bar does not move. Water comes out but it stays in the same...
(More)
The dishwasher runs but the top sprayer bar does not move. Water comes out but it stays in the same position. the top level 'stuff' is not clean. i have even tried running it empty - same problem.
My 5 year old dishwasher won't stop running. It doesn't go to the next cycle and pump out the soapy...
(More)
My 5 year old dishwasher won't stop running. It doesn't go to the next cycle and pump out the soapy water. When I turn it off and try to start over(when it will ordinarily start pumping at the start of a new cycle, it just wants to continue running. Is it some sort of timer or circut board gone bad?
6-7 yr old Bosch Integra Ltd dishwasher. Handle screws came loose. Unscrewed "star" type...
(More)
6-7 yr old Bosch Integra Ltd dishwasher. Handle screws came loose. Unscrewed "star" type screws to remove interior door panel and gain access to reattach handle. However, I can't figure out how to remove the interior panel. Thanks. Jon
