Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
Hpzd7000 notebook I've replaced my a/c adapter but it still is not working.I have two batterys,the lightening bolt flashes with one of them but not the other one.
  • Nussi Nov 19, 2007
    Have got the same problem! My HP Pavilion Zd7168 dont come up again after crashing during bootup. Curios about is that many button lights still burn when plugged in, although the main power button stays without any reaction at all.
The a/c jack on the computer is probably loose.
Posted on Dec 13, 2007
How can I tell if my battery is dead in my hp 6910p? I tried taking it out and then using just the power cord and I get nothing. When the battery is in and I turn on the power button I get an orange...
If nothing happens when you plug in your laptop, battery removed, you have a potentailly bad power adapter or DC power jack. Most likely it is the power adapter which is relatively inexpensive to replace (about $10). Click HERE to go to a listing of adapters for your model.
Apr 16, 2011 | HP Compaq 6910p Notebook PC PC Notebook
Is the lightening bolt supposed to flash orange? The battery will not keep a charge at all, so I have to keep it plugged in all the time. Does the orange flash mean I may be in danger of losing files, etc....
The orange flashing lightening bolt is confirmation the battery does not charge. It is not an indicator of any other hardware failure.
You can remove the battery if you find the flash annoying. The laptop will be lighter without the battery too!
Sep 21, 2009 | Dell Inspiron E1705 Notebook
I am having the same problem
The bios can only be flashed if you have more than 10% battery charge. check if you have any other AC adapter. is the battery does not charge with another adapter then it could be a battery or motherboard fault. Try another good known battery, If even a good known battery fails to charge then its a motherboard issue. Call technical support and get the motherboard replaced.
Rate if useful.
Aug 10, 2009 | Dell Inspiron E1705 Notebook
Aspire 1640, when i press power button, battery light flashes a few times and then nothing
that means it's not powering up... Take out the battery...hold power button for about 60secs and start the laptop with the adapter...if laptop powers up this will clear one's the battery if not then might be your adapter...check the voltage...try plugging in another adapter. Check the battery if it's working with any other laptop. Try lightening the laptop remove any external attachments[printers,scanners,pen drives etc.] All this you can try on your own and other than this leads to internal problems.Call any authorized personal from the company.
Aug 02, 2009 | Acer Aspire 1640Z Notebook
My comp shut off and wont turn on anymore.. lightening bolt comes
Please remove the battery and ac adapter and then press and hold the power button for 25 - 30 seconds after that connect the battery back and then try to turn on the machine. if not remove the battery and just plug in the adapter and then try to turn on the machine. If still not working then try to swap the ram. or else your system motherboard requires to be replaced.
Jul 15, 2009 | HP Pavilion dv6000z Notebook
My laptop HP Pavillion ZV6000, battery started decreasing and wouldn't charge when the ac adapter was connected. I purchased another ac adapter thinking that was my problem. It didn't work. Now I have...
As others have said, the most common fault with the ZV series is the power socket. However, you mentioned the Lightning Bolt. This indicates that the battery is being charged and it should go out as soon as the battery is fully charged.
If the Lightning Bolt flashes on and off regularly, especially when the power cable is moved, then the socket is at fault and needs replacing.
You can check to see if the battery is receiving a charge by doing the following
1. Right Click the Desktop
2. Click Properties
3. Click the Screen Saver tab
4. Click the Power button
5. Click the Power Meter tab
This will tell you the computer's current power source and whether the battery is charging.
I have replaced several of these sockets on ZV5000s and I'm sure the 6000 will be similar. I would not recommend this job for anyone without technical knowledge, despite some of the websites that say you can do it yourself. You will need to strip the entire laptop down and all but remove the motherboard before the socket can be replaced.
Hope this helps
May 21, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Hp pavillion will not turn on, took battery out and put back in still not working. blue light around power cord on and blue lightening bolt flashes
Hi Iceprincess5
The three flashing lights indicate the battery is dead. Since it still wont power up with the cable plugged in I'd say the port has gone. Try wiggling the adapter about in the port to see if it begins to charge. If not then you would need to take it to a laptop repair centre to get a new dc port soldered on or buy a docking station.
May 15, 2009 | HP Pavilion dv2700t 2.5GHz Intel Core 2...
Lightening bolt
The "Lightening bolt" is usually the FLASH indicator. Manual should be available at their website in PDF format for download.
Mar 29, 2009 | Fisher Price J8209 Digital Camera
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
No power to Compaq Presario
There were several recalls on Compaq's ac adapters and batteries that caused fire to units...
Check this out
I would also check with compaq about your problem. They were replacing and repairing the units free of charge due to the defects. I would check with them
Hope this helps you
Oct 21, 2007 | HP Compaq Presario R4010US (PX352UA) PC...
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
60 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
