Question about Creative Labs Gigaworks S750 Computer Speakers
Can I use my s750 speakers connect through A receiver?
Can I connect my s750 speakers to a receiver and use for my 52"lcd sony tv, I tried without a receiver, it worked but the problem is that the subwoofer over powers, i'm thinking a really good receiver wood eqaul everything out and give additional volume ,? what do you think?
  • 99 Answers
Re: can I use my s750 speakers connect through A...
I would actually suggest connecting the speakers up like that because the preamp that is used in the S750 is not very good even though the actual amps are good. I would also recommend using a different sub since it is very difficult to bypass the amp for the sub. Using a different amp could also provide more volume you would just have to make sure that you don't blow the speakers. I have a set of S750's but I have not been able to find anything to tell me the exact power handling that the speakers are capable of but I believe that they can handle a lot more than what the internal amplifier is putting out.
Posted on Nov 14, 2007
Re: can I use my s750 speakers connect through A receiver? - Creative Labs Gigaworks S750 Computer Speakers Computer...
Any more info on this?
Posted on Dec 31, 2007
0 characters
3 Points
How can i connect my 32" sony bravia?because the
Route the television audio directly through a stereo receiver. Connect the audio outputs of the television to the audio inputs of the receiver, using digital (coaxial or optical) or RCA (left and right audio) cables. Connect the left and right stereo speaker to the corresponding terminals on the receiver. Be sure that the positive and negative terminals of each speaker and the receiver are correctly lined up
Use a cable box. If your television doesn't have audio outputs, as many older TVs don't, use the outputs from a cable box to route your sound to the receiver. Proceed with a digital or RCA connection as described for the TV
Use a VCR. If you don't have a cable box, run the cable from the wall outlet into your VCR and then instead of outputting the audio to the TV, output it to the receiver so that you'll get sound from cable programming through the receiver and to the speakers, rather than to the TV. Connect the video output from the VCR directly to the TV for the easiest setup. You will then need to control your television programming with the VCR.
Change the program mode on the receiver to the input category you used to input the audio; for example, "TV," "Cable" or "Aux" are common options. You should now be able to hear audio from television programs on your speakers.
Mar 01, 2011 | Durabrand 5.1 Surround Sound Computer...
Creative T7900 Speakers
ODDS are slim without a connecting unit best bet to accomplish this is to get the dds-100 by creative good luck though as this item is discontinued and expensive even still to date. you will need osmething to decode the signal from the tv. a receiver with any surround capabilities will also work
Nov 10, 2008 | Creative Labs Inspire T7900 Computer...
Connecting Creative Labs Gigaworks S750 to Onkyo SR605 A/V Receiver
take those speakers to an electric shop and ask him for some special sockets.....
Jan 08, 2008 | Creative Labs Gigaworks S750 Computer...
Control pod
Double check the connections, if the connection for the control pod is good then something is wrong inside. I would say most likely thing would be a problem on the power supply inside the subwoofer box.
Nov 29, 2007 | Creative Labs Gigaworks S750 Computer...
3 Gigaworks S750 dont work after a central electric power failure
based on my understanding on electronics. maybe the 3 speakers your talking about doesnt resoponds to the frequencies on the music you are playing because a 7.1 souround speakers, each speakers are designed to respond at a certain frequecies.
So try playing movies instead of music and try lowering or not connecting the rest of the speakers and listen closely to the 3 speakers your talking about if you hear any sounds at all...
hope it help...
send me feedbacks...
Oct 16, 2007 | Creative Labs Gigaworks S750 Computer...
Creative gigaworks s750 bass turning off
switch off the spk and check the woofer spk audio cable connection is it loose or something .swith it on and just connect only your woofer and see r u geeting any sound from it . bye
Sep 16, 2007 | Creative Labs Gigaworks S750 Computer...
Creative Labs Gigaworks S750 Computer Speakers Logo
431 people viewed this question
Top Creative Labs Computer Speakers Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Creative Labs Computer Speaker Expert? Answer questions, earn points and help others
